Square head nuts and bolts
BrianC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BrianC Quote  Post ReplyReply Direct Link To This Post Topic: Square head nuts and bolts
    Posted: 31 Mar 2012 at 1:33pm
I am having a hard time finding square head hardware.
Are there good online sources?  Fastenal wants $5.15
for a (single) 1/2-13 x 1" grade 5 , but just $0.65 for
a grade 2.
bauerd44 View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote bauerd44 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 2:07pm
I just found a few places that carry square head bolts in various grades.  See below.
This is just a few I found.  Just do a search for Grade 5 square head bolts.
Dale
Bill_MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill_MN Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 2:08pm
restored a case trip plow last summer which had all square head bolts, didn't have much luck finding much of anything. the grade 8 bolts I needed were $36 apiece from fastenal, mcmaster-carr had them but wasn't much cheaper. I don't understand is it that much more work to make a square head instead of a hex head?
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 2:44pm
Bill, did that Case plow originallly come with Gr 8 Bolts?
Sounds like overkill, maybe?
I would guess Gr 8 square head bolts and nuts would be just a bit rare!
mnoonan-NEWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mnoonan-NEWI Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 5:25pm
AC CA, Ferguson TO-20, Ford NAA, M-M BG, AC #3 Mower, SC Plow, PH Digger, AC 720's with Ark 700 loader & Brantly Backhoe, "Mini B" w/flathead Ford V8
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 9:08pm
You have to shop a round to find some items. I think grade 8 would be rare.
My neighbor needed som special bolt for a JD that he modified. Fastenal wanted $9.95 each and had to order them. He made a few phone call and found them at a Case-IH dealer for $.95 each in stock. cost hi $9.00 instead of $90.00. Bob
hamman01 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote hamman01 Quote  Post ReplyReply Direct Link To This Post Posted: 31 Mar 2012 at 9:24pm
Here in N. Mich. we have Mid State Bolt and screw. They have a web site. You might be able to get them there.
Dusty MI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dusty MI Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 12:41pm
There is one on the west side of Lansing also. Prices are much more reasonable than Fastenal.
Dusty
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 1:33pm
Trouble with Fastenall is when they add on shipping for the dang things after the fact of the price , so like the hela-coils I bought for $1.00 each came to $12 for shipping , seeing as they were mailed in a flat pack for less than $2.00
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 2:07pm
I second this, used there bolts on the WC, can't remember the cost though.
Galatians 5:22-24
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 2:12pm
Makes me feel lucky as I have a local hardware store (old fashion) that still has bins full of them although they may be only grade 2-- not sure.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DMiller Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 4:43pm
I got the ones I needed through Lowes, had them in bins and galvanized to boot.  For longer than they had I bought nuts and all thread, ground down the galvanize and welded then painted the weld with zinc chromate spray primer.
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 7:00pm
I just had a quote for all of the WC square head bolts.  We have a fastenal store near us so there is now shipping cost the quote came to $35.00 for all of them.  I know the specs are correct.  They average just over one dollar a bolt all number twos.  I was going to get one grade 8 bolt and it was $30.00 on its own.  There does seem to be a big jump in value which seems to indicate they will make some of these but don't stock them.  Grade 8 bolts aren't too cheap for large size bolt for hex head.
Over all not too bad considering that in 40 years I dare you to try to find any parts for something you buy today.  Some TV's they don't make replacement parts now right off the shelf.
I do think its worth the cost if your restoring but if its a work tractor the hex head from the stock in our barn would be going in.  Which is kinda funny since I've replaced a lot of hex head with square heads over the years because we had them.
If you have a few to order ask for a quote.
