Allis-Chalmers G Project Questions
KD8NGV View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Topic: Allis-Chalmers G Project Questions
    Posted: 30 Mar 2012 at 3:20pm
I am working on my newly acquired G.  The one thing I noticed is there is a pipe facing downwards coming out of the Valve cover.  What is this and what does it mean if there is something coming out of it while running?
Thanks,
Kevin
Roddo View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Roddo Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 3:30pm
Its just a crankcase vent.  Usually if you have oil slobbering out of it that means you have a bit of blowby in your engine.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 5:03pm
It is pushing out a vapor of sorts...  What would that mean?
Burgie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 6:18pm
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 6:20pm
Kevin, There is a picture of that half scale G.
"Burgie"
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 30 Mar 2012 at 7:41pm
kevin, check your messages
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 01 Apr 2012 at 5:56pm
That's a nice lloking half scale!!
What would that vent pushing out a vapor of sorts mean?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Burgie Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 6:02am
Could be worn rings or cylinder bores.
"Burgie"
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 10:48am
Please excuse the green behind my ear....  How might I go about checking that?  I assume I need to take the head off the tractor, but how do I check the rings and bores?  Do I look for slop? Or what?
Thanks guys?
Kevin
Gary in da UP View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary in da UP Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 10:59am
 Inspect the plugs, do a compression test. Start there and post the results. In the meantime get manuals for your tractor.. You need them.
Post Options Post Options   Thanks (0) Thanks(0)   Quote KD8NGV Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 11:01am
I have all of the manuals for the tractor, I'll refer to them as I tear her apart.  Ill take a look at the plugs tonight.  Compression tested by thumb test or do I need a set of gauges?
JohnCO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnCO Quote  Post ReplyReply Direct Link To This Post Posted: 02 Apr 2012 at 11:12am
KD, You can get a compression gauge at most any store selling auto parts, shouldn't cost much more then ten bucks for a simple one.  You really need an accurate number on each cylinder, should be around 120 PSI as I remember.  If one cylinder is quite a bit lower then the others, that might suggest a leaky valve but if there is blowby coming out of the breather tube, it is probably worn piston rings.  If it runs ok and you aren't doing a lot of work with the tractor, you may just put off spending much money on it until it gets worse. Someone here will have better advice.
Allis Express participant
mmccarty View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mmccarty Quote  Post ReplyReply Direct Link To This Post Posted: 03 Apr 2012 at 5:31pm
As other have said, it's a crankcase vent.  All engines have a certain amount of leakage past the compression rings (blowby).  Without a vent it would pressurize the crankcase and cause problems with the oil seals.  On a modern engine this vent would be plumbed backed into the engine intake and the gases would be reburned as an emissions control measure.  They refer to this as Positive Crankcase Ventilation (PCV).
It's normal to see a small amount of vapor leaving the vent.  If it's blowing oil out on the ground, then the blowby is rather excessive and indicative of worn rings.
