Hydraulic Slipping on 5050
variscora View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote variscora Quote  Post ReplyReply Direct Link To This Post Topic: Hydraulic Slipping on 5050
    Posted: 29 Mar 2012 at 8:00pm
Howdy folks...have an early 80s 5050...noticed the bucket was slowly dropping with a load in it (very slow). I checked the hydraulic fluid and it was a little low, so I added until it came up to normal on the dipstick. Bucket with a load is still slipping.
Any ideas? Am I looking at replacing the hydraulic pump?
Thanks much ahead of time...
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:45pm
You might want to see that the loader cylinder seals are not leaking first.  Those can lower your load.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 9:51pm
Pump don't the load, the control valve holds the load.   MACK
This page was generated in 0.172 seconds.
