Need some help
JonEinNE View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonEinNE Quote  Post ReplyReply Direct Link To This Post Topic: Need some help
    Posted: 07 Dec 2009 at 6:49pm
My WD runs for a bit and then dies.  It has Petronix ignition, new plugs, and plenty of gas in the tank.  After I've been blading snow about 15 minutes, after the engine is good and warmed up, it wants to die when I let off the clutch (usually in 2nd gear).  I quickly push in the clutch and it keeps running.  I've checked to make sure it isn't choked any.  It's been getting progressively worse.  I'm guessing it's a carb problem.  I rebuilt the engine ~1 1/2 years ago, but I didn't touch the carb.  Any suggestions?  Rebuild the carb?  We're expecting more snow tonight and I'm getting frustrated.
As always any help is appreciated.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 6:55pm
Is the air breather restricted? This is something that is often overlooked when "restoring" a tractor.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JonEinNE Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 8:09pm
I just ran it with the air cleaner disconnected.  It ran the same way.  I bladed snow for about 10 minutes and then it wanted to die when I let off the clutch.  After awhile it started to chug and then wanted to die while I backed it into the barn.  Arghhh.
I guess I'll drain the gas and try to clean things out.
Anybody have any other ideas?
Osage_Orange View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Osage_Orange Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 8:30pm
Are you sure the entire fuel system is clean?  I had a similar problem with my WD a few weeks back.  It turned out that the inlet to the sediment bowl was clogged from material I used (neoprene) to make a gasket for the fuel cap.  It would run some and then try to die..........If I pulled the choke out most of the way, it would continue to run.
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 10:35pm
Definitely an obstruction in the fuel system.  Clean/replace filter, clean out bowl.  Check the passage through the sediment bowl and line.  I found a dead ladybug in mine a few weeks ago that made running difficult.
ac crazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 1:14am
CHECK THE JET INSIDE THE BOWL AT BOTTOM. I HAVE HAD MINE GET CLOGGED UP FROM MINUTE PIECES OF RUST AND IT WOULD ONLY RUN FOR TEN MIN.AT A TIME....ALSO IF YOU HAVE A INLINE FILTER CHECK TO SEE IF IT IS CLOGGING.OR IF ITS TILTED AND MAYBE SUCKING AIR POCKETS INSTEAD OF FUEL.
JohnThomas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JohnThomas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:58am
Is it frosting up? I've had that problem in the past when cold and windy while blowing snow up here.
Life is short...Make haste to be kind
Stan IL&TN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stan IL&TN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:52am
Remove the drain on the carb bowl and see if you have good flow to the carb.  Let it run to flush out any water in the bowl and to check flow from the tank.  Check the gas cap to be sure it is venting.
AllisFreak MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisFreak MN Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 12:41pm
Also, if your sediment bowl has a cork gasket it might be deteriorating and since it is on top of the screen little pieces of it get sucked into the carb. I cleaned my carb 3 times in a month before I figured it out and replaced the gasket. No problems since.
This page was generated in 0.062 seconds.
