Expensive toys |
Steve allis dozer
Silver Level Access
Joined: 10 Apr 2011 Location: Australia Points: 232 |
Topic: Expensive toysPosted: 29 Mar 2012 at 5:52am |
Have $12000 into the engine rebuild for my HD11EP project brought this tractor in 1995 has has been a long time but it is
Steve allis dozer
Silver Level Access
Posted: 29 Mar 2012 at 6:01am |
Steve allis dozer
Silver Level Access
Posted: 29 Mar 2012 at 6:03am |
Chris/CT
Joined: 11 Sep 2009 Location: Niantic, Ct Points: 1939 |
Posted: 29 Mar 2012 at 6:50am |
That's going to be purdy when done, well worth your efforts and purse book drain, nice to see folks going the "extra" to preserve the old AC Machines. They just don't build em' like they use to.
Mactractor
Joined: 20 Jun 2011 Location: New Zealand Points: 652 |
Posted: 30 Mar 2012 at 4:39am |
That the early EP with power brakes, Twin Disc converter, and tall forward gearing Steve?
jaybmiller
Joined: 12 Sep 2009 Location: Greensville,Ont Points: 25274 |
Posted: 30 Mar 2012 at 6:11am |
Only 12,000? ....cheaper than getting married !
Steve allis dozer
Silver Level Access
Posted: 30 Mar 2012 at 7:37am |
Yes has power brakes , twin disc convertor, am not sure on gearing, the radiator top grill is made of welded mesh insted of pressed holes like the late onesRegards Steve
doctorcorey
Joined: 17 Jul 2011 Location: S. KC Missouri Points: 589 |
Posted: 30 Mar 2012 at 9:11am |
B26240
Posted: 30 Mar 2012 at 12:49pm |
Steve I have a great appreciation for guys like you that take on these big projects, Besides that crawler's are in a special category cuz they are hard to move once your done therefore not easy to show. Thanks for posting the pics Mark
John (C-IL)
Joined: 11 Sep 2009 Location: Illinois Points: 1654 |
Posted: 30 Mar 2012 at 1:47pm |
I can appreciate that. Keep up the good work, you'll have a nice machine when you are done.
Mactractor
Posted: 31 Mar 2012 at 2:42am |
Your rebuild job is very impresive Steve. The grill you mentioned would be to allow better cooling. My EP (same model) gave cooling problems until I fitted a grill that allowed much more air flow. I made one with 3/8 rock sreening mesh. Unrestricted air flow with good shielding against tree limbs and scrub. Keep up the good work. Mac
Ian Beale
Joined: 03 Oct 2011 Location: New South Wales Points: 1009 |
Posted: 31 Mar 2012 at 4:24am |
Steve and Mac
The fashion around here is to make a grille with flat plate at about 45 degrees up and wide enough that they shield one another from the front. Some of our sticks can be real trouble if you push into the head of a tree with mesh in front. And this design doesn't seem to restrict the cooling.
If I work out how to post a photo I have one of these on our FA 10 but the description should work.
Ian
Ian Beale
Posted: 31 Mar 2012 at 4:41am |
Steve,
Been down a similar engine track with an AC "Forty Five".
Came with a dead engine (rod bearing). Tripped over a short motor out of a liquidation sale - with "overhauled injection pump".
Plus local help and we had two good heads and 15 injectors to test. Got 8 useable.
Then found a massive diesel leak into sump. Now know more about Am Bosch rotary pumps. The "overhaul" left ihe bottom O-ring out of the head sealing, squashed the clip holding the sub-tappet to the head for install and was one tooth out on timing.
Then we had return to idle problems, which diesel apprentice son tracked down (over about a day) to a burr on the control shaft that runs the spill valve in the head.
We've seen a lot of the insides of one of these pumps! Including the strategic extra wire on the govenor linkage on our test model from the original engine.
It started OK timed one tooth out - but the plunger was hydraulic locking until the port opened. Now needs a short squirt if ether, but runs fine after that. I think I can live with this - it is a ranch grader - but comments would be welcome
Ian
HD6 Merv
Joined: 03 Aug 2010 Location: New Zealand Points: 501 |
Posted: 05 Apr 2012 at 11:47pm |
Great effort Steve. One hell of alot of work; but if you,ve got the patience; knowhow; money; and a great workshop; you can fully rebuild most dozers; and at least then you know what you,ve got and can hopefully expect 6000+ hours of trouble free dozing.
To my way of thinking is a better option; and cheaper; than going new. Down here at the bottom of the world a new D6 is about 600,000 pacific pesos, and i can think of better things to spend that amount of coin on Hows your other crawlers going ? Don,t be shy put some pics up of them too Cheers Merv
tits tyres and tracks
they all cost you money |
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 06 Apr 2012 at 12:51am |
wow...that's a clean work area!!! whew!
Steve allis dozer
Silver Level Access
Posted: 06 Apr 2012 at 5:03am |
G'day merv here's some pics for you Series B Allis with a stick rake that I made
Steve allis dozer
Silver Level Access
Posted: 06 Apr 2012 at 5:04am |
Steve allis dozer
Silver Level Access
Posted: 06 Apr 2012 at 5:25am |
[TUBE]e1yn9oASg-s&feature=player_detailpage[/TUBE]
HD6 Merv
Posted: 06 Apr 2012 at 5:15pm |
Very impressive mate; thank you for posting.
cheers Merv
Faron
Posted: 20 Apr 2012 at 5:51am |
I just thought i would check up on your rebuild and see how it is going. My 16 is in the corner of the shed taking up space as i can not bring my self to put it to work so I bought DX175 and use it instead. |
