Two-Ten, Two-Twenty block heater needed
Oldoug View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Topic: Two-Ten, Two-Twenty block heater needed
    Posted: 28 Mar 2012 at 3:11pm
I have a customer looking for a block heater for a Two-Ten tractor.  He does not want a tank heater.  The old A-C number for the block heater is 70256703 and has been discontinued.  Any help NOS or aftermarket would be helpful.
Thanks.
Matt Folkers
FOLKERS RESTORATION
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:43pm
I don't think there are a lot of choices besides a tank heater, perhaps a heater in the lower radiator hose? The 7000 series used kit number 71281491, it was a machinery item number and nearly impossible to find in parts books, but I don't think there is a place to install it on the 220 block. I think it needs to have the later oil cooler in order to have the orifice to install it.  Are there any freeze plugs on the block to install a freeze plug heater? I don't remember seeing any frost plugs, but there might be something accessible.
AlVee View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 1:10pm
I got one from issacsons imp in nerstrand minnesota a couple years ago also the one that fits in the 210 will fit the 220 and the d-21 as long as you have the original motor.
Post Options Post Options   Thanks (0) Thanks(0)   Quote AlVee Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 1:18pm
To clarify If i remember correctly the block heaters were different i spent some time trying to find a block heater for our d-21 and the 7000 series were different than the 210-220 that's when i found the one for the 210 would fit the d-21 it isn't as deep as the 7000 series.   Hope that helps
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 2:31pm
zero start shows one that screws into the pipe plug hole at right rear of block.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:57pm
Part No.   Watt    Volt  Diameter   Type           Repl. Cord
3500013  1500 120  1" NPT   Immersion  3600008
From the Zero Start Catalog
You Might check with O'Rielly Auto. They show it for $64.99 I was able to get a heater for my 7010 from them.
Napa may be able to get one also.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Oldoug Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 10:08pm
I have the one from zero start already.  The heating element is about as long as the 7000 sereies one's from AGCO which will not fit in the Two-Ten if I remember correctly.  Thanks for all the replies.
Matt Folkers
FOLKERS RESTORATION
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 10:25pm
The Zero Start catalog says that it fits, That's all I know about it.
