220 landhandler
nella(Pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nella(Pa) Quote  Post ReplyReply Direct Link To This Post Topic: 220 landhandler
    Posted: 28 Mar 2012 at 11:41am
I have the serial no. and think it is a 1972 year. Is there a way to tell how much of the tractor is original, mainly the engine and what ever else though casting no. or serial no.? Dose the 220 have trouble with the transmission jumping out of gear like some other models? Is there a way to track it's previous owners?
  Thanks,  Nella
Edited by nella(Pa) - 28 Mar 2012 at 4:24pm
WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 2:26pm
Our 220 is serial number 1942. Our transmission does not jump out of any gears.
Fred Dunlop, G,B,CA, WC,WF, 3 WD45`s,gas, diesel and LP,U,D10 series III, D12,D14,D15 SERIES II,D17 Series IV in Gas and Diesel ,D19 GAS and D21,170 185,210 ,220 an I-600 8070 fwd, 716H and 1920H
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:58pm
I am restoring serial 1032  220. It is the 28th one built. The originial engine will be a model 3500 and have a vertical oil cooler with the coolant inlet in the center of the block.
7030's also had a 3500 engine but with the horizontal retangular oil cooler, oil filters on the oil cooler, and the coolant inlet at the rear of the block.
redline View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:06pm
  Thanks,  Nella
If by chance you have sn 2398, I could tell you a lot of history on it. I am still looking for Dad's 220 he bought new in the early 1970s.
I have 2072, it has a weak clutch, but no signs of it jumping out of gear.
Darb210 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darb210 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:11pm
I have 2383, not too far off Redline.  Maybe built on the same day?
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:50pm
Wow! That is close! I haven't found any that were any closer than yours. Good luck with it, it is the closest kin I know of.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 5:40am
Redline
There are  41  Allis 220's on the 'Owner Registry'
No.  2408 is listed - only 10 away from 2398.
Gary
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:56am
My 2 tractors is a follows. One is close to Calvins. Mine is 1038. Bought new out of Lodi CA. area. 3 point and pto.  The other one is 2134. Just PTO with factory cab and was bought new out of Saskatoon Canada.
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote redline Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:37am
Originally posted by Gary Gary wrote:
Redline
Gary
ah ha! a younger sibling. Those tractors might have sat side by side on the lot in Milwaukee at one time. Watch out, I am about to get nostalgic!
Dale Hardtke View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dale Hardtke Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:53am
Just checked my 220 serial numbers   1106   1661   1671   1694   2103   2142   2276   2689   2854   They all have original 3500 motors and none of them have transmission problems.  2276 is FWA and the last two 2689 & 2854 are 1972 models w/Allis Chalmers factory La Port cabs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 9:59am
Dale, Now I know why there aren't many 220's around here. Does anyone have a 220 earlier than my serial 1032?
