haybine
Alan (MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan (MO) Quote  Post ReplyReply Direct Link To This Post Topic: haybine
    Posted: 28 Mar 2012 at 10:43am
should a haybine ride on shoes, or should the hydraulics hold the blade and shoes off the ground?
scott View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote scott Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 10:47am
Drags on shoes across the ground not resting on the hydraulics.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Alan (MO) Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 10:57am
thanks
Mike56073 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 3:01pm
  If it doesn't have poly covering the skids, add it.  Makes the skids last forever, and slides alot nicer across the ground.
captaindana View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 7:05pm
Mike how/where do you get poly? Sounds great although I have never seen them. Make your own? I have a 489 I'd love to try them on. Thanks, Dana PS Where is New Ulm? Oh maybe Mn.?
Edited by captaindana - 28 Mar 2012 at 7:15pm
Billoh View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Billoh Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 8:12pm
I have a old New Holland haybine,springs hold the head up ,very little down pressure on shoes.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike56073 Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 8:52pm
  New Ulm is in Southern MN.  I get our poly stuff from a company called May Wes.  They are located in Hutchinson, MN.  Their website is www.MAYWES.com.  Part # for a 489 NH is 80363, and my 2011 catalog says they cost $56 per pair.  I put a pair on our 479 NH and they do make a difference, especially when doing road ditches.......Mike
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:23pm
Most of them that I have seen ride on the shoes, but you can easily lift by hand (about 50 lb). My JD moco and Hesston discbine are both adjusted like this.
Post Options Post Options   Thanks (0) Thanks(0)   Quote captaindana Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 6:39am
Thanks Mike! Did you have to bolt or rivet after predrilling?
bill2260 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bill2260 Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 7:21am
Old leaf springs welded to the shoe make a good fix for haybine shoes. Bill
This page was generated in 0.603 seconds.
