Early D17 front hubs Vs 170
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: Early D17 front hubs Vs 170
    Posted: 27 Mar 2012 at 11:28pm
Can I put 170 6 bolt hubs on early D17  spindles? Do they use the same bearings, or does it take a different combination of cones and races?
ALLIS EXPRESS!
This year:
TexasAllis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TexasAllis Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:14am
If memory serves you cant use the later 6 bolt hubs on an earlier tractor that had 5 bolt hubs.
1944 Allis C
1960 Allis D-17 LP
Brian G. NY View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:31am
The inner bearing and race are larger on the 6 bolt hub but the outers are the same.
I cannot tell you offhand whether or not the inner spindle diameter is the same.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 9:44am
Doesn't someone have access to 'Allis Dealer Parts' books to
compare P/N for spindles, hubs, and brgs. ?
Gary
mattb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mattb Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 11:49am
I had a late 6 bolt spindle on my 17. Changed it over to match the other 5 bolt. Had to measure spindle and race then order the right cones and cups to fit it. Go to a good bearing supply place they should be able to match them up.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian G.  NY Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 12:17pm
OK Gary, you shamed me into it!  LOL
The front spindle assembly (dual front wheels) for all the D-17s has the same part number.
But........The Series 42001 and up tractors use a "spacer, bearing" along with this
dual wheel spindle ass'y.
The manual says "use 237725 & 237726". Why 2 numbers, I can't guess!
I can only assume this spacer is to compensate for the larger inner bearing?
The wide front tractor spindles have different part numbers for the later tractor.
Can we assume the later WF spindle has a larger dia. for the inside bearing race?
The A-C part numbers for the bearings are:
Inner, for 5 bolt hubs:              Cone: 0222214-9  (Timken #15250)
                                              Cup:  0209987-7  (Timken #15118)
Inner, for 6 bolt hubs:              Cone: 0209899-4
                                              Cup:  0235089-0
Outer, For 5 & 6 bolt hubs:       Cone: 0209926-5  (Timken #2720)
                                              Cup:  0209983-6  (Timken #2776)
I know the Timken #s on only the bearing I have had to replace myself.
Now, I ain't no typist, so you know this wasn't easy!  LOL
I'm pretty sure I got all the numbers correct, tho.
