XT pto
alexchalmers View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Topic: XT pto
    Posted: 26 Mar 2012 at 5:34pm
Recently purchased a 190xt. It currently has a1000 rpm pto. How big of a project is it to switch to a 540. I believe it is a 67.
DanD View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DanD Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 6:14pm
I didn't realize that they came with a 1000 RPM only PTO. I've only ever seen 540 or the interchangeable one.  Learn something new every day.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:08pm
That could be the case. I have never seen an interchangeable pto on a 190. I am definitely not an expert on the matter. This is the first tractor that I have owned.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DougG Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:10pm
It can be done , but i just bought an adapter to go to 540 and run the engine slower
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:39pm
I don't know what is involved but in 1971 I was going to buy a new xt, it had 540 and I needed 1000, dealer said he would change it for me but that is as much as I know.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 8:59pm
Be careful with that. Extending the PTO changes the standard for length, which is necessary for range of motion. You can get into trouble running out of collapse in the shaft.
 I was trying to back a little red wagon with 400 bushel of corn into a shed once. The PTO shaft evidently ran out of room to collapse(nose of tractor was a little up hill from drawbar). When I cranked the front end a little and kicker the brake to straighten things out I heard a BANG. It was the PTO shaft shearing off the tractor.
Joe(TX) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:45pm
To Change you need to change 2 gears and the shaft. The early and later 190's used differant gears.
Another option is to put a 2 speed lift housing on. It used the 1000 rpm gears.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 10:21pm
Thanks for the info. Where would be the best place to find the parts for this swap? Is the agco dealer the best place to go?
darrel in ND View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote darrel in ND Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 10:37pm
Are you sure that it is not the inner changeable 540/1000 PTO? Darrel
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 10:48pm
I don't know if it's interchangeable or not. This one looks to be bolted on. I'll take a picture next time I have a chance.
kffischer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote kffischer Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 11:08pm
I bet if you unbolt it, you'll find the shaft you need inside.  only use 4 bolts at any time, and all four in the same radius of the flange.  540 uses one bolt circle and 1000 uses the other.  190 experts will need to chime in.
karl f
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 11:15pm
I have a two speed housing and all the parts from a 185 for sale....I would think that they would fit. If your pto flange has 4 extra holes all you have to do is flip it and use those holes.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 6:46am
I'll check it out. Thanks for the info. I appreciate it.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Joe(TX) Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 8:54pm
The 2 speed has stub shaft bolted on with 4 bolts to a hub. The standard does not have a hub and goes directly through the bearing which has a 3 bolt flange retainer.
The best place for the parts is from an individual or a tractor salvage yard. You can buy another tractor for what the dealer will charge.
Pete from IL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Pete from IL Quote  Post ReplyReply Direct Link To This Post Posted: 27 Mar 2012 at 9:22pm
My Dad ordered a n XT190 from the factory with  full time 1000 pto . We ran a John Deere 300 corn picker with it. It had the hyd. clutch engage. Years later I put the 2 speed housing on it for 540 pto instead of changing gears up front. The housing was from a 185, but I think the shaft in front of the housing needed to come from a 190 or maybe a 200. I got the parts from North side Salvage in Red Bud IL.
Post Options Post Options   Thanks (0) Thanks(0)   Quote alexchalmers Quote  Post ReplyReply Direct Link To This Post Posted: 28 Mar 2012 at 6:24pm
I took a closer look yesterday. It is a full time 1000 rpm pto. Looked through the manual, hope to be able to switch it out myself. All of the implements that I will be running are 540. Thanks again for the info.     Alex.
