D10 D12 hydraulic pump ?
Macon Rounds View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Topic: D10 D12 hydraulic pump ?
    Posted: 26 Mar 2012 at 1:39pm
I have a rear mounted hydraulic GEAR pump on a D10 that has been cannibalized.  Any help on locating a servicable unit or an alternate pump for that location would be appreciated. I don't plan on activating the draft control system. I just want to use it to control three point.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 2:47pm
Does anyone know if these Hydraulic pumps are used on any other Allis equipment?
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 4:28pm
What's wrong with the original pump? Fix it and be done with it.
Here is a link to new PTO pumps. http://www.splitez.com/pto_hydraulic_pumps_tractor.html
JoeO(CMO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeO(CMO) Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 4:34pm
What series D10/D12 do you have?  There were two different types of rear pumps used-depending on what series
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 5:01pm
I believe the rear mounted hyd pump on the D10/D12 are interchangeable with the CA hyd pump. Hopefully someone else will jump in and confirm...or dispel...this belief.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 5:11pm
For the sake of this discussion i aquired the tractor in this condition.
It is a 1962 model tractor, the same as a series II but not designated as such.   The pump i have is a 70236066 GEAR pump which has the Tracton Boost port.   It is mounted directly above the PTO output shaft.  No parts available from AGCO.
I would happily rebuild this one if i can find a source for parts. I am missing the main pump gears inside the pump and the shaft has deep worn areas on it.  Also one of the smaller traction boost gears inside the pump has the key sheared off on the shaft.  The pump really needs a good replacing.
  AGCO shows these complete pump no longer available as with the parts.
Visually this pump looks a little different than the pumps used on the series III tractors but the input, pressure and TB ports are all orientation in the same position.
  I appreciate all the help and sugestions.
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 7:39pm
  WE CAN FURNISH A REPLACEMENT PUMP WITH FITTINGS FOR MOUNTING
  IT COMES WITH A SPLINED SHAFT ALSO   12 SPLINE LIKE ORIGINAL    IS A COMMERCIAL PUMP HAVE HAD THEM FOR 10 YRS    1-574-342-4545 FOR MORE INFO
   COMES WITH FITTINGS TO FIT ORIGINAL SET UP   CALL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Macon Rounds Quote  Post ReplyReply Direct Link To This Post Posted: 26 Mar 2012 at 9:14pm
I LOVE this site.
I'll call ya tomorrow.
