Possible engine oil leak
EPALLIS View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Topic: Possible engine oil leak
    Posted: 25 Mar 2012 at 7:24pm
I think I might have an engine oil leak or it could be from the power steering on the D-17. I can't tell.   What is the best way to tell?  And if I find it's from the engine, what is the best treatment anyone on here has attempted?
Many thanks for any thoughts.  Thanks!
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:37pm
Clean up the area around the leak, then look for new leaking while using the tractor.  At that point you should have a better idea of what your have (engine or PS leak).
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:49pm
sprinkle flower or powder around where the leak is.  MACK
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 10:08pm
You can use UV leak tracer dye and a black light. With dye in only one compartment, it will be very easy to find out which is leaking. The dye and light can be had at Napa.
Post Options Post Options   Thanks (0) Thanks(0)   Quote EPALLIS Quote  Post ReplyReply Direct Link To This Post Posted: 29 Mar 2012 at 8:37pm
Thanks so much for the ideas.  Should there be any others out there, feel free to post them.  Thanks everyone!
