HD6 PROBLEM
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Topic: HD6 PROBLEM
    Posted: 24 Mar 2012 at 9:30pm
I have a question about a HD6 that I am looking to buy....It starts easy ...runs fine...UNTIL you put a load on or work it...then it miss'es and kind of back fires...owner says he had the pump gone through and injectors checked out ... SO Im wondering..VALVES??? ... CAM??? ...TIMEING???... PISTONS???  ...What should I look at FIRST..... THANKS
Ages Cat View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ages Cat Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 10:26pm
I would check the fuel supply. Is the tank outlet plugged? It has happened to me several times, with a rag and a cover for fuel line deicer. A collapsed fuel hose?
I have (2) Hd'6s. They are a great tractor.
gemdozer View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gemdozer Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 5:25am
Check the fuel filters and air cleaner too
Cobb View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cobb Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 8:30am
I cant believe I didnt think of that!!! I had that happen on a D4 CAT ... migtht be something else but thats a great place to start...THANKS for jar'en my brain loose
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:45am
I'd check out the simple things mentioned above first, but since the PO has had the pump off I'd check out the timing. Sounds like the timing is too high. Either way, don't take anything for granted.
Yea, I can fix that.....
