wd-45 pump problems
Chris View Drop Down
Bronze Level Access
Bronze Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chris Quote  Post ReplyReply Direct Link To This Post Topic: wd-45 pump problems
    Posted: 24 Mar 2012 at 6:23pm
when the hydrolics work it does a good job but for no reason they stop lifting and it raises real slow. It is full of oil, i have run front screw in and out several times thought a plunger might be sticking still no luck. Do i need to rebuild pump? Is the pump shot? Need some help
 Thanks,
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 6:33pm
If it comes and goes as far as working, it might be sludge build up in the reservoir. Have you ever drained and flushed the hydraulic system. It might pay to pull the pump and clean everything up.
This page was generated in 0.032 seconds.
