Identifying D15 series I or II
John Sealey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Topic: Identifying D15 series I or II
    Posted: 24 Mar 2012 at 9:15am
There is a D15 for sale advertised as a series II but it has a round muffler and the headlights are on the front of the hood. Is this a series I with series II hood decals? How can you tell if the engine is a 149ci or 160ci by looking at it? Not a deal breaker but should make a difference how much its worth. And no I'm not going to tell where it is !
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 9:52am
A D-15 series II will have a serial # 13,000 or higher. A 160 cu.in. engine will have a serial 160-xxxx stamped on the block behind the air cleaner hose to the carb. Series II will have a dry air cleaner with the intake on the right side hood panel and the headlights on the taller fenders.
Edited by Calvin Schmidt - 24 Mar 2012 at 12:52pm
Dave (Mid-MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (Mid-MI) Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 9:53am
That sounds like a series I. Look for the tractor serial # on the bellhousing, series II tractors start at 13,001. Also, the engine serial # will begin with either 149 or 160.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 10:43am
Generaally speaking:
Series 1: headlights on radiator cowl, round muffler, 149 CI engine.
Series 2: headlights on rear fenders, oval muffler, 160 CI engine.
Good advice about checking S/Ns as sometimes there have been repairs made using parts from another tractor (ie, swapping engines, etc).
Post Options Post Options   Thanks (0) Thanks(0)   Quote John Sealey Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 3:27pm
Thanks I kind of thought it was probably a series I with the wrong decals. Did the series I come with a 160 engine?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 24 Mar 2012 at 3:57pm
Series I had a 149 engine. Series II had the 160.
