wc wartime rear end
Fields View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fields Quote  Post ReplyReply Direct Link To This Post Topic: wc wartime rear end
    Posted: 21 Mar 2012 at 7:18am
I have a 1939 wc that I pull with. And have a opertunity to buy a war time rear end. the 1939 rear is rebuilt with new bearings seals and brakes. can I swap out the center section? and how much weight can I expect to lose?
ALLISMAN32 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ALLISMAN32 Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 8:18pm
Center section should be the same and able to be swapped. Dont know on the weight reduction, but it has to be considerably less. If memory serves me correctly the upper drive axle is different on the steel rearend and therefore comes apart slightly different.
Post Options Post Options   Thanks (0) Thanks(0)   Quote TedBuiskerN.IL. Quote  Post ReplyReply Direct Link To This Post Posted: 21 Mar 2012 at 9:54pm
I don't think there is much weight difference between the two.  My 1945 with the steel rear weighs the same as my 1937, not exactly, but close.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 3:00pm
The only practical reason for swapping a steel rear end into a pulling tractor is that it gives some options for easily welding brackets for tip bars, custom hitches, etc. There is not a significant difference in weight between these "war time" rears and the cast versions. The steel rear still uses cast finals. You can get steel rears to paint up real nice and shiney!! Kip
mlpankey View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote mlpankey Quote  Post ReplyReply Direct Link To This Post Posted: 22 Mar 2012 at 3:15pm
narrowing them
This page was generated in 0.896 seconds.
