Renewing brakes on a B
StanInLowerAL View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Topic: Renewing brakes on a B
    Posted: 06 Dec 2009 at 7:00pm
I have to rework the brakes on my 49 B with foot brakes.  The Service Manual shows taking the band out through the hole under the seat angle.  Is this do-able and the best way?  What about getting the new band back in place?  Any suggestions from someone who has "been there, done that" is appreciated.  Thanks, Stan
RyanTN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RyanTN Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:08pm
The link below has some insight and tips for a model C that also apply to the B.  I don't know if you saw it already.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:11pm
  they go back in just like they came out  no problems  clean cavity out  good
   we new shoes   1-800-254-3116 in stock
Post Options Post Options   Thanks (0) Thanks(0)   Quote StanInLowerAL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:29pm
Thanks, I guess I just missed the post about the brakes since it had C in the reference.  I usually read most all of them.  Stan
Bill Long View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Bill Long Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 9:26pm
Stan,  I've done a few brake jobs on a B, C, and CA, but I have to remember that was some 60 or less years ago.  All I can suggest is that you clean out the brake area well.  Remove the pin then get hold of the nut on the band with vice grips - you know when they cam out I thought I had died and gone to heaven - and work them out.  Try not to bend the bands since you can re-line them.  Perhaps there is some lining out there yet.
Take good care of my favorate.
Good Luck!
Bill Long
ps:  Listen closely to the advice given above - it is good.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 9:38pm
take seat frame off. soak the 5/8 pins good with penetrant. use an air powered chilsle gun to punch them out from the center to the outside. helps to have tires off. make sure to washo out first, get rid of all mud and mouse nests. use a #9 wire to pull out and put back in.  wrap wire around a 3 ft pry bar for leverage.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 11:01am
1945 C Allia brake removal 3
1945 C Allis brake removal 4
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
ac crazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 2:05am
SORRY TO STEAL THE POST...I AM ALSO INTERESTED IN KNOWING WHY I FIND A LISTING IN CATALOGS FOR THE LEFT SIDE DRUM BUT NO RIGHT SIDE AVAILABLE NEW OR REMAN? MY C HAS A ISSUE WITH THE RIGHT SIDE BRAKE AND I WAS GOING TO JUST OVERHAUL ENTIRE BRAKES ON IT BUT CANT GET THE RIGHT SIDE DRUM? SHOULD IT EVEN BE REPLACED OR JUST SHOES AGAIN? IS THIS A COMMON ISSUE THAT ALL B C CA'S HAVE THAT YOU ONLY CAN HAVE BRAKES ON LEFT SIDE?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 5:16am
Both sides are the same. You can remove the right side final drive and put it on the left side. You would have to turn the brake band assembly around but the parts are the same.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 5:38am
thanks for the info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:11am
Crazy, The CA is the only one that has a different brake drum on the right,since it has the differential clutch built in.
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 7:43am
More for Crazy to ponder.
   Why do both CA housings have a hole in the top for the clutch lever? I have only heard of 1 or 2 with a hand clutch on the left side.  The final drive housings  on a CA can't be swaped around like a B or C because of the off set to the rear giving a CA a longer wheelbase than a C. I guess if you could swap them around but you would shorten the wheelbase.
   If the hand clutch goes bad on a CA and you don't need it. A left side one piece CA axle and a brake drum off a B or C or a left side off a CA can take its place.
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 5:38pm
wasn't this for a shorter turning radius on end rows,only having one side due to only turning one direction when properly cultivating....lol. it was probably really due to manufacturing same casings because it would be cheaper...
