HD5 article
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Topic: HD5 article
    Posted: 18 Mar 2012 at 9:21am
 The Allis-Chalmers HD-5 crawler tractor, better known as a bulldozer, was produced by the Allis-Chalmers Company in West Allis, Wisconsin, from 1946 to 1955. It was a small bulldozer with a wide range of options for farmers, loggers, building contractors and the military. Annual production averaged around 3,000 units. HD-5 production peaked in 1953 when 4,278 units were produced. Allis-Chalmers built 29,255 HD-5 crawler tractors over its 10-year production run
Engine & Transmission
  • The Allis-Chalmers HD-5 was powered by a 2-cylinder General Motors Detroit Diesel engine. It produced 38.24 drawbar horsepower or 47.85 power takeoff (PTO) shaft horsepower at 1,800 rpm. The engine had a 4.25-inch bore and a 5.0-inch stroke. An ether injection system aided cold-weather starting. The engine drove rear track sprockets through a five-speed manual transmission offering four speeds forward and a reverse. The HD-5's forward speeds were between 1.46 and 5.47 mph; reverse speed was 1.99 mph.
Track and Suspension
  • The standard HD-5 rode on a pair of 33-link steel tracks spaced 44 inches apar, with a front track support mounted on a steel leaf spring. Optional track arrangements included 33-link tracks spaced 60 inches apart. There also was an optional 37-link track on 60-inch spacing with choice of sprung or rigid front support. Tracks were 13 inches wide with four lower support rollers per side for the 33-link track and five rollers per side for the 37-inch track.
  • General Dimensions
  • The HD-5 was 125 inches long, 70 inches wide (standard) or 86 inches wide in a wide-track version. It stood 60.4 inches tall and weighed 5.9 tons without optional equipment. It had a 37-gallon fuel tank and a cooling system capacity of 3.75 gallons. In 1955, the last year of production, the standard HD-5 had a list-price of $6,585 without options.
Options
  • Extra-cost optional equipment for the HD-5 included an eight-foot bulldozer blade and a front loader with choice of buckets from 0.75 yards to 1.5 yards. Allis-Chalmers also offered a canopy, fully-enclosed cab, track guards, radiator and engine guards, a seat-back guard and tow bars from seven inches to 20 inches wide. There also was a choice of a unidirectional 663 rpm PTO or a reversible PTO running at 539 rpm, plus belt pulleys of 10-inch or 12-inch diameter. There was a heavy-duty package with an extra-large radiator and guard, heavy-duty oil and fuel filters and an air filter pre-cleaner extension. Also available were front and rear running lights, rear floodlight and an engine-hour meter.
Read more: Specs for an Allis-Chalmers HD-5 | eHow.com http://www.ehow.com/info_8194794_specs-allischalmers-hd5.html#ixzz1pTiDUP9O
Edited by Coke-in-MN - 18 Mar 2012 at 9:23am
dadsdozerhd5b View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dadsdozerhd5b Quote  Post ReplyReply Direct Link To This Post Posted: 18 Mar 2012 at 9:45am
thanks coke. i always love reading about my machines. hard to beleive they are still running after 56 years.Smile
wayneIA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wayneIA Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:31am
The transmission, had 5 forward and one reverse gears. The loader transmission had 4th forward gear turned into a reverse, so you had 4 forward and 2 reverse gears (mine is a loader though with 5 forward and 1 reverse, I don't know why though).  This is according to my book that I have for my crawler, don't know how correct the loader 2 speed reverse is since mine doesn't agree with what the book claims, but one guy I know had one too, and he said it had the 2 reverse gears, and another transmission I've seen out of loader also had 2 reverses.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 25 Mar 2012 at 9:46am
the original configuration was with the single speed reverse , later updates went to the 2 speed. It may have been updated later , the 48 HD5B I had someone had changed the transmission to 2 speed reverse.  All the later HD5 machines I had used 2 speed except for one 5G I bought for parts , early Srl# and trany was single speed reverse.
 Unsure at that point if someone had swappd these with later or rebuilt with the extra gear . Case is the same for both .
