Bleed air from CA hydraulics?
JarrodACFan View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Topic: Bleed air from CA hydraulics?
    Posted: 16 Mar 2012 at 9:59pm
Is it possible to bleed the air from the hydraulics of a CA other than just running the lift arms up and down?
1956 WD45 Narrow Front Factory Power Steering, 1953 WD Wide Front
Allis Express in Muncie, IN
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 10:21pm
Are you sure it is an air problem?  If any water gets in the oil (possible bad boot on the gear shift??) it will cause the check balls to rust and stick in the pump....thus no pressure.  Have to pull the pump, take apart (watch for flying balls and springs) apply air pressure to ports, clean and reassemble.
ALLIS EXPRESS!
This year:
David G. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote David G. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:11pm
I worked in a hydraulic shop for several years..... that's about the only way I know, best of all its free and no special tools needed.
Gerald J. View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gerald J. Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:31pm
Bleeding is not generally needed for hydraulic power systems, only for low pressure hydraulic brakes. That's because at full pressure the air volume is very small, like 5% of an empty cylinder at 3000 psi (20 atmospheres) and that air is rapidly dissolved in the high pressure oil. So the next stroke its 1/20 that volume of air.
It is possible to loosen a connection and bleed the air, but its messy and two or three strokes of the cylinder to full pressure is as effective.
Gerald J.
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:59am
I may have been wrong, it may not be air. When I raise the lift arms up, they are jerky. They brobably go up (the arms themselves) 1/2 inch, sotp, and then raise another 1/2 inch three times in a time frame of less than a second. (not sure on measurement or time) What do you guys think is wrong or is this normal?
Edited by JarrodACFan - 17 Mar 2012 at 7:05am
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:58am
No weight on the arms would be my guess. Make the pump work by lifting something heavy. The cylinder packings may be dry also. If it sat for a time they can dry out or if they are too tight it will jerk like that without a load on it. Several cycles might lube things up and smooth it out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 10:21am
Sounds like it may be starved for oil. If the oil level is fine, maybe an obstruction at the suction tube.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote JarrodACFan Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 11:20am
Thanks, we are going to work on it today and I will see what we can do.
Edited by JarrodACFan - 17 Mar 2012 at 11:21am
This page was generated in 0.287 seconds.
