Eccentric Locks
Mike(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Topic: Eccentric Locks
    Posted: 06 Dec 2009 at 10:56am
  I am trying to put a new rim on my CA and the eccentric locks are frozen.  I do not have access to a torch.  I have been shooting them with Kroil but no luck yet.  Any other ideas?  Should I try to find someone with a torch to heat them?  Thank you in advance.
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 10:59am
  take center disc loose   lay it down an hit it with a BFH  WILL FALL APART  take out the 8 bolts first before removing from tractor
Post Options Post Options   Thanks (0) Thanks(0)   Quote Mike(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:09am
Thak you Norm.   I thought about doing that.  Will the eccentric locks come apart then so I can remove the rust/corrosion.
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:34am
I have been having good luck just driving the pins back and forth with a hammer to get them loose first....there is about 1/8" of travel without removing the snap rings.  It helps to have a good impact wrench to turn them with also. If you can't move them with a hammer, do as Norm says and soak them in diesel for awhile, drive or press the pins out and clean everything up good. I've also welded two 1/2" sockets together to make a wrench for the square head pins....then use a cheater pipe with a breaker bar...be careful  because the heads will twist off!
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 12:19pm
I think someone on here also stated to make sure that the eccentric you are working on is at 12 o clock so the weight of the tractor is off of it while you work on it.  I used the approach of taking the whole wheel center and eccentrics apart but they can be a real pain to get all back together.
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 12:33pm
Snake oil of choice. BMFH, breaker bar, socket and a big pipe for leverage. It does help to have the one you are working on at the top. I have got quite a few loose recently like this. Sometimes on real stubborn ones, I will have a helper put tension on the eccentric while I hit the socket with a hammer. Sort of jars it loose.
GregLawlerMinn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 9:35am
I do as Norm recommeends; remove the centers and locks will fall out. Remove the lock rings from the back side and apply penetrating oil of choice. Initially, I used the BFH and heat torch to loosen, however due to bad experience, I now use my press (and impact gun) to loosen the pins. Once out, clean up on a wire wheel and reinstall using a lot of neverseize on the pin (bores and under the lock...but not on the lock area that contacts the rim). Reinstall so that the non eccentric guide is on the rail with the holes for the stops. When adjusting the rims, I rotate the tire so one of the locks is on the bottom and the other two are at the 3 and 9 O'clock positions and loosen/tighten the bottom one 1st.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 11:21am
Be careful with the amount of torque you apply to a seized eccentric on a CA.
That 3/8" square nose is not near as strong as the 3/4" bolt head on larger model tractors.
I do as some have suggested - remove rim from tractor, remove 8 bolts for the 3 eccentrics and the dummy one.
I put the eccentric in a vise, heat with a torch at the two narrow areas near bolt head, then immediately work the bolt back and forth with socket and breaker bar.
I use the 3/8" square end of a socket on the eccentric with a long nut to join two sockets together.
Don't forget to remove snapring first.
Clean rust away with wire wheel and apply antisieze.
Gary
Cal View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Cal Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 6:14pm
After taking them out of the rim I like to through them in the shop wood stove at night and let the coals burn the rust out, then they can cool slowly over night. Take them out next morning and they turn like new, it does not seem to take any hardness out as I hake done this to many for years. Of coarse lube well before reinstalling. Cal in Ct.
Dipstick In View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dipstick In Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 7:49pm
Cal had a good idea, I'll have to try that. I took mine from a WD and soaked them in muratic acid for a week, but with frozen water now you can't do that outside and you darned sure don't want the fumes in a closed shed!! But the acid will eat the rust out of threads even!
Post Options Post Options   Thanks (0) Thanks(0)   Quote GregLawlerMinn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:38am
Link to a post on the old forum re: loosening eccentrics. Thanks Larry
This page was generated in 0.135 seconds.
