Lift Latch Brace
Jim-Ohio View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Topic: Lift Latch Brace
    Posted: 16 Mar 2012 at 4:18pm
Could someone post pictures and dimensions so that I could make the brace that goes between the lift latches that I just bought for a D-17. Thanks.   Jim
'61D17, '51WD, '51CA, '41C, '49C, Woods 5'&6'Mower, 6'Blade, CA-Plow, CA-Cultivator, 3-Btm snap-coupler plow, 4-row planter, WD 4-row cultivator, 80R mower,#7 mower,B/C mower
BobHnwO View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 5:26pm
Mine measures 1 1/4"X32",prolly could use black iron pipe.
Dave (NE) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:21pm
unsure what you mean by brace.  if you are talking about the pipe that goes horizonal between them, yes, I could get a picture.
tony View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tony Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:16pm
Not to hijack the post but what's the brace for?
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:20pm
That brace is a solid shaft, not a piece of pipe, and they still got bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:33pm
Yes, I'm talking about the horizontal shaft that goes between the lift latches. I'd like to see a picture of one to see how it fastens to the lift latches.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:37pm
It has bolts through it and through the latches
jiminnd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jiminnd Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:44pm
I think mine had roll pins thru it, be a few years since I removed one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:21am
Could someone give me the measurement between the center of the holes in the rod for mounting to the latches? A picture of one would still help me to get it made right. Thanks
Edited by Jim-Ohio - 17 Mar 2012 at 7:23am
Post Options Post Options   Thanks (0) Thanks(0)   Quote BobHnwO Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:29am
I don't have a bar on mine but it should be 30" center to center on holes.
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 7:34am
I would think one drift pin or bolt would be sufficient to hold the crossshaft in place.
Your lift arms may have got bent slightly sometime over the last 50+ years,
therefore the distance between the holes would be different.
OR just drill one hole, then install the brace and 'mark and drill' the other hole.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:04am
Take a tape measure and measure between the holes. Best do like Gary said and drill and pin one before you mark the other. It doesn't take much of a twist in either arm to make that center distance change.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:05pm
Thanks for the info. I'll get a rod and just drill the hole on one end until I get out to my son's in Iowa where the tractor is.   Jim
AC WD45 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AC WD45 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:32pm
Once again, what were they for?
German Shepherd dad
1957 Allis Chalmers WD45
#WD234847
1951 Allis Chalmers WD
#WD88193
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:55pm
They were primarily to keep the lift arms from twisting and thus breaking from stress.  I would bolt one side and then (I would use a Hi-Lift jack) push the other side out to the 30" (If that is correct).  And I wouldn't push it a lot if it is bent in that far either.  Gotta use some common sense on that part.  They really help on heavy loads, such as a big disk and plowing.  That's where they tend to get bent.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave (NE) Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:26pm
Here are some pictures I took.  Hope this helps.  The bar is solid.  It measured 32 3/8" from outside to outside.  As I understand it, the purpose is so the equipment does not put so much side to side pressure on the lift arms that the lift arms break.  Someone correct me if I'm wrong or provide a more complete explanation.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jim-Ohio Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:50pm
Dave,  Thanks for the pictures, helps a lot.   Jim
