My Project 48'B
juniorp53 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Topic: My Project 48'B
    Posted: 16 Mar 2012 at 3:16pm
newbie here sharing pictures of my project  of what i believe to be a 48' B  it sat like this for ten years after the sale of the farm was in running condition when it left but needed a ring gear
 couldn't believe that 3 of the 4 tires still had air in them
 drained what seemed like 3 gallons of water from inside the engine as the exhaust was left uncovered
Still in process of tearing it apart
No surprise as to what i found
I guess my question is as ive some people talk about rebuild kits.. are they all the same  because the prices seem to differ as much as $200 and as  a  student i am not looking to spend a ton of money  but i also dont want to do this again. Also what muffler is this suppose to have on it ? Can i have the holes in  exhaust manifold welded shut? they are not very big?
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 4:48pm
Welcome to the board. On rebuild kits yes there is differances in them, I will let someone else reccomend what one is the best. I'm not very fimaliar with the B's. Your holes on the exaust manifold, can be welded but are you sure you want to. If they are there from the factory why would you want to?
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 5:26pm
stray,
      Guess i should have clarified the "Rust holes"  in the top half of the exhaust manifold. There not to big and id like to save myself from buying a new manifold
dave63 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote dave63 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 5:28pm
Exhaust manifolds get thin and develop small holes in the thin spots, they can be welded if there is something to weld to and you understand cast iron welding. It is likly that it is to thin and it may not work out.
The universal answer to all questions is yes, how much do you want to spend?
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:29pm
Just buy a used manifold off ePay....
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:28pm
If it is rust holes I wouldn't try, I'm not saying that it can't be done, but I feel it wouldn't be worth the time when you can buy a aftermarket for around $100.00.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:56pm
If you are paying a welding shop to weld it, you're wasting time and money. If you think you can weld it and your time isn't work much, give it a try. I bought a nice original manifold needing a data plate for $3 at an auction last year. I plan to mill it flat and find a data plate so I can use it on my B.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:05pm
I believe you have an allis c with a wide front. The draw bar in the picture with it on the trailer seems to look like a c. I could be wrong tho. As for the manifold, don't waste your time or money trying to weld up the holes in it. Just get another one. They aren't hard to fine and don't cost that much. I may have one I could sell u. Looks like it has potential. Wish I had it.
Aj.
Edited by AJ - 16 Mar 2012 at 8:08pm
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:27pm
Sure looks like a C to me too. What is the tractor number stamped next to the shifter. Unless it has been assembled from more than one original, I bet it starts with C.
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 8:57pm
Does the wide front C steering arm point down out of the steering gear like a B or up like a CA?   Tim
wfmurray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wfmurray Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:08pm
I have a 49 B  and it has adj front axle and same as C rears.They offered two kinds ,one was stanard and one was adj front axle which came with the C type rear wheels
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:16pm
the rear end looks kind of wide, like a C, and the rear wheels look deep dish like a C.... but the steering box in the  4th photo is definitely from a B and the front axle is a B.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 6:55am
Sounds like someone "pieced" this tractor together at one point in time.
Can't fix stupid
Post Options Post Options   Thanks (0) Thanks(0)   Quote juniorp53 Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 8:31am
I always wondered the same thing myself as i never knew that model C came in a wide front end version. the model number next to the shifter starts with B the next number after that is 8 but i cant remember beyond that. We had a C back on the farm and when parked next to each other the Rear end of the C was noticeable wider so i believe this to be a B with the optional adjustable front end  also has the rear lift to which i have the plows for one bottom for one direction and the other bottom for the other direction. not sure of model number  not sure how many options where available my guess is this one has a few of em
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 17 Mar 2012 at 1:14pm
They could have put rear axle housing on the B to make it wider. If it starts with a B and has a wider housing thats prolly what they did. So it would sound as if your tractor is alot of tractors in one.
Can't fix stupid
