tranny dipstick?
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Topic: tranny dipstick?
    Posted: 15 Mar 2012 at 9:01pm
okay, next little item:  same 52CA
picture shows where i have been replacing oil (10-30, can't find recommended 20w).
just a pull off cap, no dipstick like i've been reading about.
now gonna drain & replace with ATF from recommendations here on the forum, and i know from reading where to find the drainS (plural).  and now i know capacity, so will put in correct amount.  was leaking so badly before i was unsure of how much to replace, so slowly added some till wouldn't drain down anymore and was 2" below rim.
right place to be filling?  and should there be a separate dipstick or attached to cap?
Edited by CAdon - 15 Mar 2012 at 9:04pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:04pm
Think i would go with Universal tractor fluid rather than ATF.
the UTF has a better rating for gear use and also the additives for foam and water dispersal .
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:07pm
okay.  actually found some in the local auto supply and bought it just in case.  i've seen enough of your other posts to follow your advice!  thanks.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:43am
I think you just got the ATF mixed up with the UTF.  About the only thing I use ATF for is making up some rust releaser. Equal parts of ATF and Acetone. Shake it WELL every time.  That's what I have in mine, Universal Transmission Hydraulic Fluid.  Works really well.  STILL have a 5 gal bucket of 20w I bought a few years ago and never use except for the oil change and when that is gone, I am going to switch over to 10w-30w.  A LOT easier to get.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:04pm
Yep, universal tractor hydraulic fluid in my CA and D17.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:22pm
CAdon there  is suposed to be a dipstick that goes in there 1/4 twist to keep in place. one of the vendors on this site should have one for  sale. When full  oil level will be about at the bottom of that opening.
This page was generated in 0.043 seconds.
