CA starter removal
CAdon View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Topic: CA starter removal
    Posted: 15 Mar 2012 at 8:38pm
starting with a simple one:
1st problem ever running it (engine purrs all day long).  starter just whines, like it's not engaging flywheel.  gonna pull it and see if just basic crud in there is causing malfunction.
so i presume i just disconnect at the top and undo the machine screw in the clamp and wiggle out the starter?  (blue circles)  and what the heck is that bolt for inside the green circle???
if it's anything like the automotive starters i've rehabbed before should be no problem.
only timid approaching an apparantly original piece i'd hate to wreck.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:41pm
Disconnect power from the solenoid  and unscrew bolt in green circle to remove...
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:45pm
thanks.  you just saved me from a probable disaster.
Dick L View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dick L Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:46pm
No reason to mess with the clamp at the back unless you are checking the brushes. If it whirs that part is probly alright. The bolt/stud in the green circle not only holds the starter in the correct position it is also the means for a solid ground for the starter.
Edited by Dick L - 15 Mar 2012 at 8:48pm
TMiller/NC View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote TMiller/NC Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:47pm
Remove battery cable first.  Disconnect the cable from top of starter (top blue circle), remover bolt in side (green circle), slide starter out of bell housing.  No need to remove the band around back of starter.   Tim
We talk slow in NC..........type slower
Edited by TMiller/NC - 15 Mar 2012 at 8:49pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote CAdon Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:49pm
any more questions why i LOVE this forum?! thanks guys.
