draining trannie oil on a B
didgood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Topic: draining trannie oil on a B
    Posted: 15 Mar 2012 at 7:48pm
Just changed the motor and trannie oil in my B.  Before I pulled the plugs on the transmission and pto housing I checked the oil level and it was ok.  I pulled the front plug first and the pto plug second after the oil was mostly drained.  I got very little oil out of the back plug.  Is that normal?
Thanks
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 7:57pm
Yes that is normal. There are 3 plugs, don't forget the one under the PTO.
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:02pm
The PTO housing has a gasket on it that goes half way up the cover and traps about a cup full in the PTO housing area so the pump always has oil if you are on a downward slope. The front  or center plugs will do most of the draining.
Post Options Post Options   Thanks (0) Thanks(0)   Quote didgood Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 8:48pm
Nuts, I thought there were three. I missed one in the front somewhere.  I got the one in the center of the transmission housing and the one on the pto housing.  Where is the other one up front?
