a/c in my AC 7060
Ben (MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Topic: a/c in my AC 7060
    Posted: 15 Mar 2012 at 6:04pm
I have my 7060 in the shop having a few things fixed. I got the bad news today that the a/c compressor is leaking coolant. I would like to delay the repair until the fall. If I keep the system charged, do I stand any chance of doing further damage? I'll run it 100 hours or so this year. When I bought the tractor last year the a/c was pretty cold and it took most of last season to loose it's cooling output. Thanks for any info.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:27pm
Should not hurt any thing.  MACK
Dave in il View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave in il Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 9:36pm
About the only thing that could happen is the leak gets worse and you lose your coolant
AGCO My Allis Gleaner Company
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 7:59am
Depends. I take it they say it has a refrigerant leak, probably around the shaft seal? Does it have grease buildup around the pulley? The problem with leaks is depending on where, how bad, and how long it has been leaking, you loose compressor oil that circulates with the system. Loose enough oil and the compressor shreds it's self. Have you switched it to R134? There are "oil charge" cans available. If you plan to charge it your self, I'd add at least one oil charge, probably two. If I remember correctly, the 7060 used the Fridgidaire A6 compressor which is one of the easiest compressors to change a shaft seal on if you have the tools.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ben (MI) Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 9:02am
Thanks everyone for all the info. It does have R134 in it and the refridgerant is what is leaking. I will watch for oil to be leaking until the compressor is replaced, I will have to have it done because it is beyond my capabilities.
Edited by Ben (MI) - 16 Mar 2012 at 9:03am
roscoe View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote roscoe Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:40am
If you keep the A/C turned off, the clutch will not allow the compressor to rotate, so there should be no damage.
Roscoe
Edited by roscoe - 16 Mar 2012 at 11:41am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 6:01pm
You won't see a leak dripping any large amount. What you're looking for is a buildup of grease/dirt around the pulley/clutch plate. If there's a big build up there, I'd add oil to it. You can buy "oil charge" cans that have 2 oz of oil and about the same amount of R134. You use a low side charging hose to put it in. It's pretty simple to do, just have to follow the directions and don't forget to purge the air from the hose. Too much oil is far better than not enough.
