Allis Chalmers G hydraulic issue
ccaissie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccaissie Quote  Post ReplyReply Direct Link To This Post Topic: Allis Chalmers G hydraulic issue
    Posted: 15 Mar 2012 at 2:39pm
Hi:
Diagnosing a 1953 G, with weak hydraulic function, i.e. raises only 1" slowly. Pump is not noisy, but am not sure about oil level....is it the transmission case that's used as the common reservoir?
I have adjusted the knob on the front side of the top assembly, assuming it's the pressure relief setting...no changes.
So, is this a valve issue, a pressure setting, a suction/supply issue or is the pump just shot?
Thanks for any help on this,
Colin
Ted in NE-OH View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted in NE-OH Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 2:43pm
The hydraulic reservoir is the transmission case, so check level of transmission fluid.Smile
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccaissie Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 3:59pm
Since I couldn't find a separate reservoir, I assumed it was common, like the old crawlers using 20-30wt.
I've heard that using 90wt gear oil can cause a problem, but it seemed to be thin oil, like motor oil.
I've also heard that since the pump actually works, it is best to check the suction tube, ports, relief valve etc.
The tractor will be at my shop next week, so looking forward to a simple fix, but if you've got further hints, I'd like to hear.
Thanks,
C
JoeM(GA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote JoeM(GA) Quote  Post ReplyReply Direct Link To This Post Posted: 15 Mar 2012 at 6:01pm
C, check your email, sent you some reading
Joe
Allis Express North Georgia
41 WC,48 UC Cane,7-G's,
Ford 345C TLB
Post Options Post Options   Thanks (0) Thanks(0)   Quote ccaissie Quote  Post ReplyReply Direct Link To This Post Posted: 16 Mar 2012 at 11:22am
Thank you very much!
C
