185 repair ?'s
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Topic: 185 repair ?'s
    Posted: 03 Mar 2012 at 9:39am
You install the brake drum assembly on the shaft first and then slide the axle assembly into the rearend housing. Make sure you have the brake bands adjusted loose enough the drum will slide inbetween them.
This page was generated in 0.168 seconds.
