D17 brakes
Brad-MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Topic: D17 brakes
    Posted: 14 Mar 2012 at 11:37am
Need some help guys....I got a broken brake rod on an early D17.  The problem lies in where the rod broke, just inside the brake housing.  Do the brake bands come out the top inspection hole, or do I have to take the whole side of the tractor apart to get to it.  If they do, what's the easiest way to get it all apart, fix the problem and reassemble the entire apparatus?
1930 U
1938 A
1941 WF
Rick View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rick Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 12:00pm
Brad,  You take the brakes out of the top of the hole where the cover is,but you have to get that dang bottom pin out first!  Rick
donais View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 1:14pm
Also that front shoe might be a bitch to get out if it broke long enough so it won't pass by the drum and housing
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brad-MN Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 1:26pm
How does the bottom pin come out...does it have to slide out towards the tire, as in having to be pulled out?
1930 U
1938 A
1941 WF
Post Options Post Options   Thanks (0) Thanks(0)   Quote donais Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 1:30pm
Yes in bolt the keeper bolt and prey that the pin will slide out I made a slide hammer puller. Others have used other methods
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 4:41pm
Those pins can be a real b*****d to get out. On mine, I welded a bolt to the head of the pin, slipped a deep well socket over it, and pulled with a nut and flat washer.
