Roosa inlet pressure...
Wes (VA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Topic: Roosa inlet pressure...
    Posted: 13 Mar 2012 at 9:43pm
If they've got too much inlet pressure from an electric pump..what will that do to the inj. timing?  on a 7080 that didn't come out with electric pump.  thanks, -Wes
Post Options Post Options   Thanks (0) Thanks(0)   Quote MACK Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 10:17pm
It will advance timing at cranking speed and make it harder to start. Could make it knock at idle. Advance screw can be adjusted for the pressure.  MACK
injpumpEd View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 6:32am
what pump are you running, & how much pressure is it rated at?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 8:10am
Ed, its got a carter pump of somekind..didn't think to try and put a gauge after and see what its puttin' out.  I'll see if I can do that today and see what I've got.  Mack, it sounds like I may be on to somethin' here then.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 12:19pm
I'm gettin' 4.5-5 psi off the electric pump..  seems like I saw somewhere thats ok pressure..right?
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 2:39pm
that won't hurt a thing. When calibrating roosa pumps we typically supply pump with 3-5 psi from test stand, per Stanadyne specs.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Wes (VA) Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 4:28pm
Ok thanks, guess I'll keep checkin'..I haven't run new lines from the tank (to try and eliminate air)..they look like they've been on there a while.  Though someone has put a hose from the block type filter to the inj pump, and it has a loop that runs about 4" above the fuel filter level, then back down to the inj. pump.  im wondering if air isn't gettin' trapped in the top of that loop, but with the electric pump..it ought to push it through.  Probably just need to pull the pump and send it off.
Post Options Post Options   Thanks (0) Thanks(0)   Quote injpumpEd Quote  Post ReplyReply Direct Link To This Post Posted: 14 Mar 2012 at 4:33pm
I guess I missed what your problem / complaint is? Need more history about what the symptoms are.
