long frames
farmer_rob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Topic: long frames
    Posted: 05 Dec 2009 at 7:35pm
can anyone tell me why allis frames were longer on the wc/wd/wd45's. i realize it was easier once the desiels came out having the longer frames. but that said that was a very long time to be making long frames for nothing. was it a case of making the tractor longer for better balance??? making it longer make it have a smoother ride??
just wondering rob
if farming was easy everybody would be doing it
Post Options Post Options   Thanks (0) Thanks(0)   Quote steve(ill) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:02pm
i have also wondered that same question. why the big chunk out in front of the radiator?
Post Options Post Options   Thanks (0) Thanks(0)   Quote ChuckLuedtkeSEWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:38pm
Do you think it was because of the attached implements?  Like on the WC, they had the hookup locations in front of the radiator for the cultivators to slide into, and then the weight of the cultivators were right on top of the front wheels.  And then the trend carried through to the rest of the line.  I guess the WD/WD45 cultivators had those different mounting brackets but it did keep it further forward of the radiator as well.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:46pm
ok chuck thats a good idea but thats an awfull long time to using that design . those tractors didnt get power steering till the mid yrs in the wd45's. just wondering what was the real function for the long frame .
norm [ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm [ind] Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:48pm
  you better get the ruler out an measure them diesel is same laength as the gas tractors  proved lots wrong before my auction had both setting side by side  had to prve it to them
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote farmer_rob Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 9:09pm
i know both gas and diesel farmes r the same lenght.. my question is why did they go with the longer frames so long before coming out with the diesels
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 9:15pm
My guess would be that they needed to put the pedestal out in front of the engine and that is where it wound up after allowing for a front mount pump.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 8:41am
I'll stir this pot a little, Put a tape to a WD and then do the same thing to a 400 Farmall and then a 60 John Deere and you will find the WD is about the same wheel base, Maybe a little shorter. And if you don't have some weight on the front end, The tractor's front end will be up in the air all the time. I like to play with colors on here! LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 10:49am
Well I have been thinking about this and now I'm more apt to believe it was because of the row crop configuration starting back with the WC. Based on the rear wheel spacing needed to cultivate corn, the front wheels had to be out that far in order for the rear wheels to follow the track of the front wheels while turning. I've seen literature showing a sketch of the WC with front mount cultivator turning at the end of a field of check-rowed corn and  the path of the wheels doesn't touch a single plant.....maybe a little bit of wishful thinking, but on paper it looked good!
Don Smith View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don Smith Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 11:46am
Gentleman: The reason The wc wd wd45 RC are long framed is a QUESTION OF BALANCE! More weight on front wheels Less wheel float in a hard pull. I hope this load of Bull Sh%#t Puts your brain to thinking strange toughts. Don in Indiana. THINK SPRING!
D-17_Dave View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote D-17_Dave Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 3:13pm
Could it be that the mounting slightly ahead of the front wheels ment that correcting the alignment for rows while cultivating was easier. The front bolster being forward and spacing the radiator back for room to mount the cultivators would do this. This WAS mainly a row crop, cultivating tractor.
ac crazy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 2:30am
IT WAS BECAUSE A SHORTER FRAME GIVES A HIGH SPEED WOBBLE IN THE STEERING!LOL AND BACK THEN METAL WAS CHEAPER THEN THE LABOR TO CUT IT OFF....
Edited by ac crazy - 08 Dec 2009 at 2:30am
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 6:50am
The wheelbase of a WD is 88 inches while a M and Super M are at 84 inches. I'd bet a JD A is also a shorter wheelbase and I know my Massey 30 is shorter (like about 8-10"). Maybe that's one reason why a WD can outperform most others in the field. TB helps too.
Wink
I am a Russian Bot
Scott(SC) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Scott(SC) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 8:28am
I would say space for cultavators, weight displacement, and more leverage for turning pull behind equipment. We have a 20 disk 3 point harrow that almost raises the front on the MF 135. My D14 can handle it with ten cement blocks added on it.
Embellem View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Embellem Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 1:10pm
Had to be a good reason since a WF doesn't have that extra length in front.
Whatever the reason is, maybe it is the same reason why Case DC and SC tractors have their pedestals way out front of the grill
Josh IA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Josh IA Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 1:52pm
    It's a great place to set tools or other objects when performing work on the tractor:)
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac crazy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Dec 2009 at 5:31pm
its really for the farmer to have a seat when he has cranked and cranked on his tractor and it wont start...lol
