What do I have?
DonDittmar View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Topic: What do I have?
    Posted: 12 Mar 2012 at 8:28am
I am working on getting my AC stationary powerplant up and running. I thought it was a model B engine, but the number in the block is CR46664GA.....is this a CA engine designed for gasoline?? Also I thought someone had a chart made that you could identify the year of the engine off this number.....
1968 D15D,1962 D19D
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:44am
Don
Here is a link to Bryan Smiths website:
Gary
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:55am
From Bryans B / C / CA  Serial number list your engine appears to be a 1945.
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:56am
So was a correct in assuming it is a gas burning CA engine?
Gary, thanks for the link
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:59am
Well, by Bryan's site it looks to be a 1945 C engine
Thanks again for the link
1968 D15D,1962 D19D
john(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 12:25pm
Hey Don,  What are you going to run with it?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 2:00pm
My air compressor. Tired of tieing up a tractor when I want to sandblast so I am going to switch it over and run it with the C engine
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote john(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 2:11pm
I was thinking along that line.  I was also thinking maybe belt a generator to it somehow?
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 2:30pm
Could.
If you were camping you could belt a BIG alternator to it and use a DC power set-up type of thing. Thats what we do with our pop-up when attending tractor shows. Pop-up plugs into 2 deep cycle batteries that are in a box I built. We have a 10SI alternator belted to a 5HP Briggs....which is attaced to an old lawn edger. When the batteries get low just fir up the "law edger" and charge up the batteries.
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 2:51pm
Don, Early B's had the BE engine. Later B's and all C's and CA's had a CE engine. I think the CR had something a little different for the power units used on combines and as portable power units. Seems the CR might have been used in the RC but I might be mistaken.
 I'm sure there will be somebody jump in with more or better information.
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 3:26pm
The CR is for power units and I don't know of any serial # list to find out what year it is.
Darrell, Jr. (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell, Jr. (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 7:14pm
we also have a engine that was a combine power unit and it also has the CR prefix.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ted J Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 9:24pm
My 1941 C has an engine with a serial # R 16312 G.  I don't know where that came from either.  As far as I was told, there is no way to find out.
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 9:35pm
I think the R prefix can be either an RC motor or a power unit.
Chalmersbob View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Chalmersbob Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 10:52pm
I think the R engine was used on the RC tractor and the CR engine was a Power Unit engine used on combines and balers. The ones used on combines had a shorter spring on the govenor, and run at 1900 RPM. These have a gear box on the Rockford clutch housing. I bought one with a straight shaft coming out of a Rockford clutch unit, also fitted for a starter. and it had the standard tractor spring on the govenor. Bob
Ken in Texas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ken in Texas Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:00am
on page 4 of my Parts Manual AC-P-B-C under the heading
Engines
CR- Prefixed number (3 3/8" bore, 1900 r.p.m. ) used in :
60H Gasoline Power Unit PU53977-B and up
60H Low octane Fuel Power Unit PU-55480-B and up
There must be a power unit serial number somewhere on your unit
Also noted is R prefix engines were used in 60H Gas power units prior to PU-53977-B
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:22am
Thanks Ken
Maybe there is a tag on the clutch housing, I guess I never looked. The rad shroud has a CA decal on it, but I guess that dont mean anything
There is no gearbox on my clutch housing, straight shaft.
My enigne came from a sawmill
1968 D15D,1962 D19D
Post Options Post Options   Thanks (0) Thanks(0)   Quote DonDittmar Quote  Post ReplyReply Direct Link To This Post Posted: 13 Mar 2012 at 7:27am
Also, I need a starter. The ring gear is on the flywheel, but it was set up as a hand crank as there is a plug in the starter hole and I want to change that. Will a B starter work?
1968 D15D,1962 D19D
This page was generated in 0.162 seconds.
