Picture posting again PLEASE!!!
DarrylinWA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DarrylinWA Quote  Post ReplyReply Direct Link To This Post Topic: Picture posting again PLEASE!!!
    Posted: 11 Mar 2012 at 12:23pm
Guys, I am so frusterated I cant figure this out again. Would someone walk me through this again. Thnaks in advanced, Darryl. P.S. If I see someone at the GOTO this year in MN. I will buy them a milkshack for there help Tongue
Thanks Darryl
B 10 Custom. Serial # 1001 D21, First D21 built 69 #4498 and Last D 21 Built #4609. 1946 MM UTU. And 2000, 2005 Pete's. AC custom Hauling.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Coke-in-MN Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 12:54pm
Seems since the update all bets are off of easy posting , I have found several ways to do it but unsure if others have a easy way.
Posting pictures from on here (on site storage) doesnt seem to transfer right so i open the picture then do copy -past rather than try to post the link from site.
 Seems others are using photobucket or other such off-site storage and can get it to work.
 Just like with you tube videos I post using the film strip , I have to enter the share tag line once then close the site and reopen and enter it again then it will post.
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 1:08pm
I use photobucket,have no problems posting picturs from there .
Rfdeere View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Rfdeere Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 2:12pm
   I agree with Fred, Photobucket works for me. And there is no limitation to how many pictures you can have on Photobucket, so as long as you don't delete or move them on Photobucket, the pictures will be on your posts here. When you delete pictures from the system on this site, it also deletes them from all the posts they are on.
Edited by Rfdeere - 11 Mar 2012 at 2:12pm
http://www.rumelyallis.com
stray View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 7:20pm
From Photobucket it is real easy, just place the curser over the picture and I menu will drop down. Go down to the IMG code and left click, if your watching it will flash copied. Then go to your post and right click, then paste. A link will apper with [IMG] on each end that is you picture. Be sure to hit enter between each so it will stack on top of one another.
1969 190XT series 3
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 7:27pm
To post on site, you have to start a new post or use the "Post Reply" button if you are replying to a post. Then cllick on the icon that looks like a tree. Click on browse find your picture then open it, and click on upload. A warning will tell you to be something about it will take a few minutes. The picture should show up and then hit OK. If you have posted it before you should be able to find it in the menu after you click on the tree.
1969 190XT series 3
Brian S(NY) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian S(NY) Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 7:51pm
I notice that it says a max of 2 mb.. my pics are in KB will they still work or do I hafta do somthing different? Thanks Brian S
also my pics are way big how do you get them to a more manageble size so it is same as screan and you dont hafta scroll to see it all?
Edited by Brian S(NY) - 11 Mar 2012 at 8:09pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote stray Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 8:34pm
MB is bigger than KB. You sould be fine as long as it isn't bigger than 2000KB. But if it is close to the 2000KB you may want to resize it, if it's to big it isn't enjoyable to veiw.
Edited by stray - 11 Mar 2012 at 8:39pm
1969 190XT series 3
