7030 won't move
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Topic: 7030 won't move
    Posted: 11 Mar 2012 at 8:56am
I'm not familiar with the 7000 tractors. I bought a 7030 canopy tractor that has sat outside for a few years. The owner died at 42 and his girlfriend does't know much about the tractor. I don't want to try to start it until its in my shop and I can check things more closely. Tried to pull it onto my trailer yesterday and the rear wheels won't turn. 20 speed trans in nuetral on the stick and console. It had been very cold the night before and I suspect there is water in the bottom of the transmission or rear end that was frozen. Going to try again today with temps in the high 40's. Is there anything else I should look for?
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 10:07am
Make sure the range lever on top of the rearend is moving when you take it out of park have seen cables get tight and feel like its moving the range lever out of park but the cable is broke you can see it from the right side of tractor behind the batteries take a light Niel
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 11 Mar 2012 at 5:36pm
No problem rolling with warm temps today. Oil is milking colour so there is water in the oil. Brakes must have been frozen. Thanks for the tip Niel.
This page was generated in 0.031 seconds.
