C Allischalmers throttle spring
Ricky G View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky G Quote  Post ReplyReply Direct Link To This Post Topic: C Allischalmers throttle spring
    Posted: 10 Mar 2012 at 6:05pm
Can some one tell me where that little throttle spring
goes  on a model C
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 7:06pm
There is one that goes from the rod between the governor and the carb that goes up to the manifold. should be a little hole in that rod just toward the radiator from the carb.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 7:11pm
If you are talking about the anti surge spring (a small light extension spring) it connects to the throttle shaft about half way between the carb and the front cross shaft. There is a little hole there. The other end connects to a manifold bolt I believe, above and toward the front.
Edited by CTuckerNWIL - 10 Mar 2012 at 7:15pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Ricky G Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 10:34pm
Thanks i got this tractor from a fence
did not have one when i got it just trying to make
it run again after overhauling the engine
