Adding Photos
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Topic: Adding Photos
    Posted: 10 Mar 2012 at 4:51pm
How do you delete photo's out of the image properties. When I click create a new topic and the Image Properties comes up and click browse and go to my albums I can't add a photo because my images properties is full. How do you delete photo's out of the Image Properties area???
MNLonnie View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote MNLonnie Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 4:57pm
Click on member control panel on upper left of this page then click file manager and you can chose which ones to delete.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 5:04pm
Whenever you delete from your file manager, they disappear from the post you used them in. If you use photobucket.com, they will stay in your old post as long as you keep your free photobucket account
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 5:19pm
Thanks !!
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 7:36pm
Jim. Since you taught me how to post photos, I have a tip for you. You need to downsize the photos before you hit the OK icon.  My new camera up loads 2036 x 1524. I down size to 999 x 750  (4 to 3 ratio) which is about right. Just remember to keep the ratio the same or it gets distorted.
Zyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Zyta Quote  Post ReplyReply Direct Link To This Post Posted: 10 Mar 2012 at 7:45pm
Yah, I need to do that! I took those using my blcak berry and I should have re-sized them.
Thanks.
