Fuel shut off, 2 valve
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Topic: Fuel shut off, 2 valve
    Posted: 09 Mar 2012 at 8:43pm
Seen this at the farm the other day. Grandpa said he took it off of a 'C' tractor at some point in the past.
Would this have been used for the 2 gas tank version??
Tough pictures to see, but thats all I could do with my cell phone. There are 2 shut off valves on above the bowl. And what type of bowl is that?
Galatians 5:22-24
pumpkinman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote pumpkinman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 9:59pm
  Don    That vave was used on duel fuel tractors [ C E K ] motors . Thay had a small one gal gas tank under the hood plus the reg. fuel tank . You would turn the small tank [gas] on to start and bring motor up to temp. then turn it off and turn the big tank [Kero ] on when you shut down you would turn the big tank off and let the motor run out of fuel.You could restart eng. if it was still hot if you stalled if not you had to drain the carb. and restart on gas.       Kent
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 10:28pm
