I have a few 190XT questions.
Gary (sw Wis.) View Drop Down
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Topic: I have a few 190XT questions.
    Posted: 09 Mar 2012 at 8:05am
I have no Hi Range on the Power Direct at all. Where do I start checking things?
Where can I buy the tach cable. And how much?
How do I test the temperature sending unit.
Are the clamps that hold down the battery deck plate and hold the grill cover available?
Thanks
190XT - D17 - D14 - WD45 w/loader - WD - (2)B110 - 616H - 610 - B-208 - WD with 190 Mounted Corn Picker - All Crop 60
Austin(WI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 8:13am
PD: Does the tractor even move when you put it in High Range?
Tac Cable: You can find those either on retailers on here or Through AGCO ( Usually between $20-$40)
Temp: Take the little wire plug end off and ground that cable somewhere on the tractor. If the needle on the gauge gets burried the sending unit in the block is bad. If the gauge doesn't do anything then gauge is bad, but you sending unit might be bad too.
Latches: Grill cover ones are available, but I believe are either $20 or $30 per latch through AGCO. Not sure about the battery box lid.
Edited by Austin(WI) - 09 Mar 2012 at 8:13am
"Better By Design"
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 8:19am
You might have to split the tractor to fix the PD. Worn disc plates could be the issue. Only fixed a couple PDs and that is what needed to be replaced.
"Better By Design"
tractorman View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote tractorman Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 8:25am
we had a problem with both the high and low , first we checked drained and replaced the hydrofluid for it , it was low and works fine now. So check  it first if you haven't already .
Play on 38 B 49 WF , working on D14, D15 B10, Bee 12 B110. use 185 and 190
Post Options Post Options   Thanks (0) Thanks(0)   Quote Austin(WI) Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 8:58am
Yea, def. helps to have some oil in it. On our D19 the who PD was warped or something.
"Better By Design"
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 09 Mar 2012 at 8:59pm
Check the PD control valve. Mine had a snap ring pop off so the rod was moving but not the piston. Put new snap ring on and good as new. Not sure on the others.
Silver Level Access
Silver Level Access
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary (sw Wis.) Quote  Post ReplyReply Direct Link To This Post Posted: 12 Mar 2012 at 8:16am
Bump.... Thank for the responses guys I hope to get back to it this some time.
