Pulling A G Steering Wheel
oldironguy View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Topic: Pulling A G Steering Wheel
    Posted: 07 Mar 2012 at 5:31pm
Any secrets on how to do it?  I've soaked it with WD-40 for a month now and that puppl is still stuck.
Dick
Warren(Oh) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Warren(Oh) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 5:34pm
A hammer helps, tapping, soaking, maybe even some heat but it just pulls straight off. They didn't have NeverSeize when they were put on ! ha
G-Money View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote G-Money Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 5:39pm
I went through the exact same thing and asked the same question.  I had it soaking in PB Blaster for some time, but ultimately it was heat.....I mean red hot ,  and it finally came off.  I also knew I was putting on a new wheel afterwards.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Tracy Martin TN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 6:53pm
Get someone to help.Loosen nut a few turns. One person can hold steady pulling pressure on steering. Other person holds a good size hammer again outer surface of hub, then with another hammer whacks oppposite side of hub. It should come loose then. HTH Tracy Martin
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:14pm
I have used a puller on mine with great success, once you have some good pressure on the puller I give the puller bolt a good quick whack and off they come.
Don(MI) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MI) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:21pm
Have taken them off as stated above before. But occasionally you get the tough puppy that just wont budge. If I remember right, I think I used a sawzall with a metal blade, and cut almost all the way through the collar, but not too far that it hit the shaft.
Took a cold chisel then, and hit that in the open cut. Crack, expanded that collar quick and came off then.
Galatians 5:22-24
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:26am
Most important thing is to not damage the shaft otherwise sounds like any of the above ways will work.
Dave Richards (WV) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Dave Richards (WV) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:49am
I use a split bearing puller.  Load it up, Hit the top of the loaded shaft, rinse and repeat.
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 7:57am
If you are replacing the wheel, I'd cut the old one off and not damage the sheering box from all the hammering on the shaft.
Don
Gary View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Gary Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:01am
Don makes a very good point.
While you are pounding away on the Steering Wheel - what damage are you causing at the other end inside the Steering Box ?
Gary
Post Options Post Options   Thanks (0) Thanks(0)   Quote oldironguy Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:18pm
Thanks guys.  I'll be at the farm tomorrow and will work on it some more. It's nice to know that I'm not the only one who has faced a problem like this.
Dick
