WC Frame Rails
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Topic: WC Frame Rails
    Posted: 07 Mar 2012 at 6:57am
Does anyone know if a set of frame rails from a styled WC are the same as its unstyled cousin?
Redwood View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Redwood Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 7:20am
I believe the agco site lists them as the frame, but also list a base frame for the 201 power unit.  If you look there you should be able to confirm.
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 7:41am
Yes they are the same. If anybody could find any difference in them, I would like to see it.
Kip-Utah View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Kip-Utah Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:46am
We used some from an unstyled 38 on a styled 39. They appear to be exactly alike. Some earlier WC's used smalller bolts for the front pedestal than later tractors, but they are in the same location so they just need to be reamed out to the larger size if using them with a later pedestal. Interestingly the late unstyled rails that we used even had all the holes needed for the generator mount?! Going from Styled rails on an unstyled tractor everything should bolt right up. Kip
Edited by Kip-Utah - 07 Mar 2012 at 10:52am
Fred in Pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Fred in Pa Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 11:02am
I am parting out a WF maybe you can use them parts on something ? ?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 12:39pm
Nah. Can't use the rails from that. They're to SHORT....Cry
Unstylish View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Unstylish Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 12:49pm
How much for the rear end?
Darrell G (MN) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Darrell G (MN) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 1:55pm
Steve why would you capatalize the word Short, thats and invintation for ole Fred to get on you about being vertically chalanged.
B26240 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote B26240 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 2:48pm
Kip is probably right on the bolt holes, other than that the only dif I know of in any of the frame rails is the air cleaner cutout on the left side rail of the RC
Calvin Schmidt View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Calvin Schmidt Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:07pm
I don't blame you Fred. That WF looked fairly rough ! You likely have a lot tied up in storage by now.  LOL
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:45pm
Thanks guys!
Post Options Post Options   Thanks (0) Thanks(0)   Quote Steve in NJ Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 6:55am
Big D,
Do you really think that's gonna entice him to say somethin' like that? He doesn't need any invitation. It just rolls out pretty easily. He's always hard on me and Harvey. But I'm tough, I can take it!  LMAO!!  Big smile
gary ny View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote gary ny Quote  Post ReplyReply Direct Link To This Post Posted: 08 Mar 2012 at 8:25am
Steve What do you need  I can help you out .I have two 1 styled and one unstyled. email me
This page was generated in 4.936 seconds.
