retainer on b/c
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Topic: retainer on b/c
    Posted: 06 Mar 2012 at 11:50am
Is the retainer (part# 226006) on an allis c not normal or common. Input?
Can't fix stupid
morton(pa) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 1:46pm
I don't have my parts book handy. Can you elaborate a little more? I'd be more then willing to help if but you have to be a bit more specific. Engine part? Fuel system part?
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 1:56pm
Looks like a cover of some sort that goes over the exhaust manifold.
Can't fix stupid
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 2:05pm
It is a cover for the kerosene manifold to help keep the manifold up to temperature.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote morton(pa) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 2:22pm
Ah. I believe I know what you are talking about.
The answer is No, not very many B's and C's were fitted with them. They were only installed on the ones designed to burn Kerosene. No need to worry if you don't have it.
AJ View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AJ Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 4:24pm
Are they very common?
Can't fix stupid
