One down, 3 to go.
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Topic: One down, 3 to go.
    Posted: 05 Mar 2012 at 9:14pm
Finished up the brakes on my 175 tilling tractor today, it needed nothing but cleaning up. Someone had put brakes in it recently and gooped up the balls and tracks with anti-seize compound (which caused them to lock up when it was warm and humid enough to get the stuff gooey)....DON'T use anything on the balls when doing the brakes!!!
Now it is on to probably the biggest project, the 175D I bought from the west side last spring.  The LH side brake rod is twisted off, which means the cylinder has to be removed to get to the lower pin.  I removed the fender and loader frame  today and can't even get the spring pin out of the cylinder pin...not a good sign.
Then it is on to my "nice" 175D and D17 SIV high clearance diesel....I should be really good at this by the time I am finished....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote SteveM C/IL Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 10:04pm
Thems good brakes when clean and dry.Dust causes trouble after time
ac160 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 8:29am
Eldon, how does the loader frame connect to the rear axles?  I just took the same model off my D17 and it looked like the frame had been modified.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:26am
It has a U type bracket from the top which goes thru a V cradle underneath that has a flat bottom.  The frame sits up against this cradle and two long bolts welded to the U bracket hold it all together.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 9:01pm
4 hours to get the easy side apart this afternoon.....split a socket and used lots of heat. The pin to the 3pt cylinder came out easier than expected, but was eaten away pretty bad. Hub seal was out and final drive gears are noisey, am putting 185 finals on it.  You guys that live in the rust belt can keep your tractors LOL!
ALLIS EXPRESS!
This year:
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 5:39am
Eldon when you get all your tractors refitted with new brakes come on over and do some of my WD45's. I have two in need of your hands on knowledge of rusty brakes one is a WD45 and one is a D-15II with things hanging out the holes in the bottom of the axle. Smile
Don
Post Options Post Options   Thanks (0) Thanks(0)   Quote ac160 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:54am
Thanks, that helps check how close mine is to original.
Edited by ac160 - 07 Mar 2012 at 9:55am
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:10am
The main frame looks like a standard design with provisions for special ends designed for the individual tractor.  I will try to take some pictures and post them....still need to download my old camera software to the new laptop.....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:12am
Don
Thanks Don...you just reminded me that I have a D17 SI with the brake pin from hell still sitting here waiting......
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 9:07pm
Here are some pics of the loader mount
ALLIS EXPRESS!
This year:
