lil off topic oliver ???
XT in pa View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Topic: lil off topic oliver ???
    Posted: 05 Mar 2012 at 7:25pm
im working on  a 1600 oliver with a 1800 or 1850 engine (wont know till i get crank out) this engine has sat for a while and it  ran the first time today . i took the manifold off and the exhaust ports are bout pluged with carbon . and the intake manifold has 3 nice holes and the other 3 sucked the gaskets in to the middle of the hole and there is carbon built up in the holes that have the gaskets messed up . this is not turboed   what causes this mess lol    Shawn
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote XT in pa Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 6:47pm
bump   any help
190XT,D17and 7045
Post Options Post Options   Thanks (0) Thanks(0)   Quote CTuckerNWIL Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 6:54pm
It sounds like it could have had different problems over time. The burned out manifold could be from running lean and that could be caused by a warped manifold that wasn't sealed or maybe the block surface isn't flat.
 The carbon-ed up part could be from burning oil or leaking exhaust valves???
