b riveted wheel
Glockhead SWMI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Topic: b riveted wheel
    Posted: 05 Mar 2012 at 7:17am
I have a b riveted front wheels. One is in very poor shape. How hard are these to find? What are they typically selling for? I'm going to attempt a repair but I'm not getting my hopes up.
wjohn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:36am
I picked up a complete non-adjustable B front end with riveted rims in nice shape from a forum member for $100 a couple years back. I don't think they're worth too much, especially since there are quite a few out there (12,000 tractors or so, maybe? I think Glenn said they were used from the end of '38 halfway through '39) and the bolt on wheels are easier to deal with.
Is the whole wheel bad or just the rim?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 8:42am
just the rim. been repaired before and was hacked. pretty nasty.
Post Options Post Options   Thanks (0) Thanks(0)   Quote wjohn Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 1:27pm
Tony Carbaugh has rims that should work. Although I haven't personally tried them, I bet they would be good. He says they're a "perfect fit." I've never measure my rims - I wonder if there is a size difference between the riveted and 5-bolt, and even the cast wheels?
http://tonystractors.com/acr.htm
Scroll down toward the bottom "3x15 Blank." Some forum member might have a used wheel for the same or less money, but again I'm not sure on value.
GlenninPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote GlenninPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 2:48pm
Grind the rivets off that hold the center to the rim (NOT the ones holding the hub to the center!) and knock the old rim off. Put the center in one of Tony's rims and re-rivet, or just spot weld them in place. Voila' good as new.... Pretty easy fix.
Good judgment comes from experience. Experience comes from bad judgment.
From listening comes wisdom and from speaking comes repentance.
Wise men learn more from fools than fools from the wise.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Glockhead SWMI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Mar 2012 at 3:40pm
Thanks guys. Glenn, that is what I'll have to do if I can't find a good used one. This one is shot.
