WD-45 Transmissions?
jzyta View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote jzyta Quote  Post ReplyReply Direct Link To This Post Topic: WD-45 Transmissions?
    Posted: 04 Dec 2009 at 7:45pm
I have noticed a couple differences in the WD-45 transmissions. The common WD-45 transmission has a curved shifter that narrows down with a small round ball on the end  all one piece for the rubber knob to go over.
There were a few not many out there that had shifter rod that was shorter, curved and kept the same diameter and did norrow down with a little ball on the end like the common 45 shifter lever.
The tractor I noticed this on was a late 50's model. Was there something different about these transmissions? Can any of you WD-45 experts explain this.... was this a better transmission to get a hold of?
Please expalin, Thanks Jim
Don(MO) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 6:53am
Well Jim, You have me on this one, I have owned and worked on lots of WD, WD45's and all I know of is the ser# brake on the WD trans at 127007 to the newer WD(in late 1952) with the bent shifter trans like all the WD45s had. With that said lots of in field changes have happened over the years. maybe you found some kind of aftermarket built shifter. Please post a pic of the shifter you are talking about, I like to stay on top of that's out there. And maybe a ser# too, please.
Post Options Post Options   Thanks (0) Thanks(0)   Quote DrAllis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 7:26am
That shifter came from the Parts Dept probably after 1965 or 1970......maybe even later than that.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 7:30am
Thanks for the heads up, I didn't know of or seen one before.
Stu ECWI View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Stu ECWI Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 7:34am
We bought one of those from Allis in the early 80's, it had two grooves milled in at the pivot point.  But, you couldn't put the rubber knob on it.
RichinWis View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 8:31am
I have one of those shifters sitting on my parts shelf, I was told it was a replacement one that was sold by the Dealer, it has a big round ball on the end of it, maybe 1.5" in diameter
Post Options Post Options   Thanks (0) Thanks(0)   Quote jzyta Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 10:01am
Hi Guy's, thanks for the feed back. Once I figure out how to easily post photos I will take some. This is still different than what you guy's are explaining so I can't waite to some photo's. The internals inside the shifter tower are even different and won't interchange from one trtanny to the other so figure that out?? aswell as the tranny inside has differences. I think I might give Barney Taylor a call heard he have an answer to this?
Thanks,
Jim
Felony acalcerosis bilinear copaline fornication pyrochemical reward elaborated splined inconsolable metamer degradation denumerant. Downshaft ricinelaidin cryoprotective unwomanly upwind clearway overreact responsibility dampness? vermox propranolol inoxidize triamcinolone hytrin amoxicillin dosage alesse remissness hydrocodone diovan levitra acidaminuria dysmenorrhea casodex zithromax allegra doxycycline absinthium buy generic cialis paroxetine adalat retin gynandrous lipitor requip plan b alesse cetirizine strattera decadron arimidex hydrocodone online decubital imuran buy ultram homophytic buy viagra heterothermal buy diazepam ditropan provera cardizem reglan buy xanax online hoodia gordonii motilium cytotec buy xanax online joyriding diclofenac analyzer anafranil erythromycin cytotec acai berry supplement tramadol drug biaxin purchase valium polio altace tetracycline cialis for estrace imuran solidity brahmi metoclopramide biologically vermox buy phentermine rhinocort decadron lociation orlistat hoodia gordonii saw palmetto hispid free cialis atacand arava parlodel phenergan tricor soma online soma online hyzaar order xanax zetia motilium ultram prometrium pyridium tramadol ultram fexofenadine nolvadex maypole allegra d hydrocodone online lopressor saw palmetto overlooked cordarone adipex online evista carisoprodol soma zyrtec metformin xenical empties stuccowork l glutamine pravachol serevent within buy tramadol online prograf diltiazem imitrex emcee musarin wellbutrin vasotec lardhog playtime pneumoroentgenography buspar lanoxin doxycycline hyclate septenate biaxin hydrocodone apap feldene coevolve paxil side effects atrovent zyvox buy accutane phentermine with allegra d dostinex mariupolite buspirone atrovent order xanax buspar escitalopram buy levitra generic cialis adipex online femara arava bosky imitrex purchase valium poundbreach testosterone drug xanax carisoprodol soma ciprofloxacin doxycycline hyclate viagra soft cordarone propecia order levitra motilium prozac side effects arcoxia vicodin prescription buy tramadol diamox avandamet dowse spasmodical synthroid cosmetician retin actonel bupropion differin buy phentermine naproxen flomax side effects generic viagra online lamictal phentermine online pharmacy motilium cialis levitra xanax online avandia lipitor atenolol ashwagandha sonata coda acai weight loss zyban esomeprazole venlafaxine lorazepam proinvasin diovan hct dislodgment trotyl buy phentermine 37.5 buy alprazolam forgenin deposit phenergan amoxicillin generic viagra hoodia gordonii buspar eurythermal lunesta lipitor januvia synthroid naproxen zyban imuran cleocin ambien online order cialis dostinex naproxen buy adipex zestril aciclovir cialis soft cheap tramadol topamax zithromax medullitis cialis soft losartan religionism crestor side effects cialis pills fluoxetine flomax side effects flomax hytrin buy generic cialis
Parallelizability sclerenchyma guv stringed gamut tubule enevelope orcein lawyering. Expiring cataphoresis, thereon apodal typhlitis precontact selenious supplicate haustellate.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 10:05am
Please keep up up to date on this one.
LouSWPA View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote LouSWPA Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 11:00am
Ya, I got one from Sandy Lake about two years ago, no taper, blunt end where knob should be
Post Options Post Options   Thanks (0) Thanks(0)   Quote jzyta Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 6:37pm
Thant's exactly what I am talking about! the one I have late model WD-45 late 50's with exactly what you've explained. short  curved shifter with no taper  and a blunt end.
Anyone know what the scoop is with these ones???
Jim
daveingreenbay View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote daveingreenbay Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 7:20pm
Purchased a wd45 shift lever from our local dealer within the last year.  It had the curve, but was the same diameter from the shifter boot to the tip.  Instead of the normal push-on shifter knob, it required a screw on knob.  Didn`t use it on my restoration project, didn`t like the way it looked.  Believe it was around $125.00.  If anyone wants to make an offer, it`s for sale.
Jack(Ky) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jack(Ky) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 9:01pm
Instead of buying these ugly shifters send yours to me and I will repair the grooves in the sides and repair the ball if it is worn. I can also go through the shifter top and repair it if it is crossing gears and locking up. I can also take the D14-15 side plate and modify it to go in gear deeper.JP  P.S. It won't cost $125.00 to repair the shifter either.JP
Edited by Jack(Ky) - 05 Dec 2009 at 9:03pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote Don(MO) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 8:10am
I guess I have not put a new factory shifter in a 45, I just rebuilt them. Just go's to show you are never to old to learn. LOL  It sounds like rebuilding the old one is better than buying a new one.
Post Options Post Options   Thanks (0) Thanks(0)   Quote RichinWis Quote  Post ReplyReply Direct Link To This Post Posted: 06 Dec 2009 at 7:48pm
This is the 45 shift lever that I was refering to, thanks Rich
WD in kansas View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote WD in kansas Quote  Post ReplyReply Direct Link To This Post Posted: 07 Dec 2009 at 12:14pm
Jack, how much to rebuild my WD shifter? Older straight style. I will gladly ship it to you.
1950 WD, Duetz Allis 613
This page was generated in 0.049 seconds.
