WD Wide Front Parts
birdhunter View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote birdhunter Quote  Post ReplyReply Direct Link To This Post Topic: WD Wide Front Parts
    Posted: 04 Mar 2012 at 8:10pm
 I am looking for spindle support bushings for a wide front on my WD.  I am also looking for worm shaft seal for the same front end.  Any help would be greatly appreciated.
Also do you know if there are seals in the around the crank shaft that goes through the front support mine is leaking and I don't see anything referenced in the manuel I have.
Thanks,
Mike
