Odd Wheel Rail Clamps on D17
AllisUpstate View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Topic: Odd Wheel Rail Clamps on D17
    Posted: 04 Mar 2012 at 4:00pm
I've been slowly working my way around the D17 IV that I got last year, and I noticed the left rear wheel has a different setup than the right.  The right one is normal with eccentric clamps and a stop.  The eccentrics are bolted to the inner steel wheel with two bolts.  However, the left one has only guides, but no eccentric clamps, and is bolted to the wheel with only a single bolt.  All the thrust is being taken up by the single stop clamp.  I wondered why I would hear a clunking sound sometimes when backing up or on a side hill.
I will need to find a new inner wheel and eccentrics, but I am just curious where the wheel came from?  Or, can I find eccentric clamps that use a single bolt to the wheel?  I will try to get some pictures, but the inner wheel must be AC, but I find it odd that anyone would make guides that follow the rails without eccentric clamps.  I was wondering if anyone knows what other AC model the inner wheel might have come off of.  These are 18.4 X 28 tires on 16" rims.
Thanks.
DennisA (IL) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 4:40pm
 Sounds like you have a wheel set up off an earlier D-17 and a later d-17.
The single bolt set up is correct for the D-17 IV.
Thanks & God Bless
Dennis
norm[ind] View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote norm[ind] Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:04pm
    D-17IV USE THE SINGLE BOLT SYSTEM  ALSO 190 USE TOO  THE PROEBLEM WILL BE FINDING THE CENTER FOR THE D-17IV EITHER WILL WORK SATISFACTORLY
Post Options Post Options   Thanks (0) Thanks(0)   Quote DennisA (IL) Quote  Post ReplyReply Direct Link To This Post Posted: 04 Mar 2012 at 7:07pm
 I myself like the earlier style better than the later.
Thanks & God Bless
Dennis
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 4:43pm
Thanks to everyone for the help on this.  I still have a question though.  I finally took a photo of one of the left wheel clamps.  It is a little hard to see, but there is no eccentric clamping bolt at all - the clamp just rides on the rail, and the only thing stopping it moving are the two stop clamps running through holes in the rails.
Here is the "normal" two bolt eccentric clamp on the right wheel.
The thing is, the left wheel clunks especially on side hills, as the clamp bangs back and forth against the stops, while the right wheel is tight and secured by the eccentrics (plus its stop clamps).
It just seems odd to me that there are no eccentrics on the left wheel clamps at all, and that all the force is being taken up by the single stop clamp.  Is this the normal setup for the 1 bolt clamps?
Thanks.
nevans View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote nevans Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 6:29pm
There are two different stops that ac used a narrow one and a wider one probably who ever had the tractor before you didn't get the wide stops and used what he had Niel
DSeries4 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DSeries4 Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 9:46pm
Top pic is for series III and up (even 6000 series uses them).  You have to tighten that nut real tight, but does need the locks (on both sides of it, unless you are on the innermost position).
Eldon (WA) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 9:57pm
I use a 3/4 drive socket with a 4' cheater bar to tighten mine up....
ALLIS EXPRESS!
This year:
Jordan(OH) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Jordan(OH) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:17pm
The single bolt style is still a clamp. It was used through the 8000s. Look closer it is like a ramp, if it is loose it needs tightened or the rails are worn.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:28pm
Good thing about them is they don't seize up like the eccentrics....bad is they never seem to slide as smooth as the old style.....too loose and they will walk right off the rails and then it is "jack time"....they are pretty forgiving as far as rail wear. They have a lot of adjustment, I have never seen all the clamps tight against the center.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:37pm
I love you guys, but you are losing me here.  What clamp??  On my left wheel, there are really no clamps, just the guides running over the rails, and the stops stopping everything.  There is nothing to loosen or tighten.
What am I missing here?
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:52pm
Those "guides" actually wedge between the rail and wheel center as you tighten the big nut.
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 10:56pm
Eldon,
Thanks.  So you mean I should tighten the big nut holding the clamp to the wheel to tighten things up?
I apologize for being stupid on this, but I don't see how that would work.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:05pm
Yep. It looks like you have weights on so that might make it harder to see what they are, but the wheel center has an angle in it to match the "guide".  As you pull the two together by tightening the bolt it wedges outward locking itself against the rail. This is the nut I use the cheater bar on because it takes a lot of torque to get it tight. After I adjust the wheel spacing I carry the socket with me because it usually needs to be re-tightened after using it a bit. The bolt has a rectangular head on the back to keep it from turning....
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:14pm
Eldon,
Thanks, and I deeply respect your guidance on this.
So you mean, I need to tighten the single bolt holding the clamp to the wheel?  I think I am still dense on this.
No offense to the AC engineers working on this design, but I think they might have designed such a thing on a Monday morning after a bad night out.  It doesn't make sense to me to design something that way.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:34pm
Look at the  bolts and tighten the ones with the least amount of threads showing...there should be a gap between them and the wheel center.  It they are all tight against the wheel center, your rails are worn. If they have been run loose the rails could be worn in that spot.  I would then move the wheels in or out one stop to an area where the rails aren't worn .
ALLIS EXPRESS!
This year:
Post Options Post Options   Thanks (0) Thanks(0)   Quote AllisUpstate Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:41pm
Eldon,
Thanks.  I will look at it in the morning, and see what is going on.  I see what you are saying though.
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 06 Mar 2012 at 11:42pm
As far as the engineering goes, I think AC was trying to alleviate the problem that a lot of us have come upon...rusted eccentrics! If the old style aren't moved at least once a year, chances are they will be rusted tight....then you have to fight that problem. Yesterday I had to move the wheels out on my 175D. They probably had not been adjusted since the tractor was new (40+ years).  All I had to do was loosen the 4 big bolts a couple of turns and then spin the wheels out, a 5 minute job. If they had been the old style eccentrics it would have taken me all day to free them up.
ALLIS EXPRESS!
This year:
Lonn View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Lonn Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 6:27am
I prefer the newer style with the one big nut. I've adjusted my D19 and 7050 with those and no troubles. The 7050 is a workout cause there are more and you need a cheater pipe but I've watched a farmer fight with his 4020 with rack-and-pinion. I'm not sure if he ever got them to move. They were slamming the axle with a 16# mall trying to move the worm screw and had been at it all morning. On my 19 and 7050 they never give trouble but you really have to tighten then evenly so the run out on the wheel is minimal. Works well for me. Go look at the spin out wheels on an old IH 450 and you'll see an engineering flub. They never hold well.
Edited by Lonn - 07 Mar 2012 at 6:28am
Wink
I am a Russian Bot
Matt MN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Matt MN Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 7:52am
another idea here, is it possible that some one used the newer style eccentric clamp on an older style wheel center and that is why he cant get them tight enough and they are making noise?
Cant really tell from the picture.
bradley6874 View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote bradley6874 Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 8:51am
Mat iam with you that looks like a stamped steel wheel all the one bolts i have seen are on cast centers and have a wedge cut in the cast that matches the lock a stamped wheel wouldnt have enough wedge to tighten with out bottoming out
Post Options Post Options   Thanks (0) Thanks(0)   Quote Eldon (WA) Quote  Post ReplyReply Direct Link To This Post Posted: 07 Mar 2012 at 10:03am
All the 28" wheel centers are stamped steel...Matt might have a point about a different clamp being put on...I am only familiar with the D17SIV, 170/175 and 180/185 and 190 clamps. I would think any other style would be different enough that they wouldn't even bolt up...but you never know.
ALLIS EXPRESS!
This year:
This page was generated in 0.223 seconds.
