gravity wagon tracking ?
old man mi View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote old man mi Quote  Post ReplyReply Direct Link To This Post Topic: gravity wagon tracking ?
    Posted: 04 Dec 2009 at 6:35pm
 Can anyone tell me what the toe-in should be and any other things to look at or do to get a wagon to tow better . I have a  decent 8 ton gear and four matched 11l 15" 8 ply tires thanks   steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote Brian Jasper co. Ia Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 6:54pm
I would set it to about 1/8" toe in. That's what I do for heavy duty pickups with a straight ft axle.
DaveCinIN View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote DaveCinIN Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 6:58pm
Make sure the tongue is straight with the wheels. It will go down the road better when loaded if the tongue is in straight with the tongue. The 1/8 inch toe in should be good.
Edited by DaveCinIN - 04 Dec 2009 at 6:59pm
Post Options Post Options   Thanks (0) Thanks(0)   Quote old man mi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 7:15pm
 thank you for the replies.  the linkage is tight and has grease zerks.  replaced some bolt and bushings. The toung has a bend in it so I will make a new one Thanks Steve
Post Options Post Options   Thanks (0) Thanks(0)   Quote old man mi Quote  Post ReplyReply Direct Link To This Post Posted: 04 Dec 2009 at 7:16pm
I need spell ck. sorry
Nathan (SD) View Drop Down
Post Options Post Options   Thanks (0) Thanks(0)   Quote Nathan (SD) Quote  Post ReplyReply Direct Link To This Post Posted: 05 Dec 2009 at 2:04am
If your wagon tongue drops to the ground after you unhook it from the truck it is too loose.
