What does this serial # tell me? |
Post Reply ![]() |
donkey ![]() Silver Level ![]() ![]() Joined: 06 Feb 2012 Location: Central MO Points: 152 |
![]() ![]() ![]() ![]() ![]() Posted: 04 Mar 2012 at 2:04pm |
Hello All,
I went out and got the serial number off the D17 today. d17-12651-M does this make sense? I was afraid to scrub to much more for fear of losing any additional letters or numbers. Thanks Jeff |
MNLonnie ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Baxter MN Points: 4791 |
1958?
CTuckerNWIL ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: NW Illinois Points: 22825 |
OK what's the M for?
I shouldn't have posted so fast. Is that an engine # or a tractor #? I really don't know anything about the new stuff.
I found it. S is low octane and M is gasoline, it's an engine # so I don't know what year it is.
Where would I find tractor number?
Thanks |
Stamped on the left side flange of the bell housing.
Brian G. NY ![]() Orange Level ![]() ![]() Joined: 12 Sep 2009 Location: 12194 Points: 2262 |
I'm guessing the tractor number will be somewhere around D-17 18000 making it an early '59 Series I tractor. It will probably have the early style oil filter as used on the WDs and WD-45s. The color should be Persian Orange #1 and the rear wheel centers are probably orange rather than cream.
I used the difference between your engine number D-17 12651 and my engine number
17-29111 (16460 units) and subtracted that number from my tractor number D-17 34633 to come up with an estimated tractor number of D-17 18173.
There is not a direct correlation because there were engines built for combines and stationary units that were included in the same series of engine serial numbers.
I hope you post your tractor number when you locate it just to see how close I came.
Skyhighballoon(MO) ![]() Orange Level ![]() ![]() Joined: 11 Sep 2009 Location: Pilot Grove, MO Points: 3115 |
As already stated, that number is the engine serial number found on the left rear side of the engine block somewhat behind the carb. M-code is a 7.25:1 compression ratio gas engine. If the code was "Z" it would be 8:1 compression...don't have my Swinford book but I think "V" code was the 8:25:1 compression gas engine such as found in the 175. Mike
1968 Gleaner EIII w 10' & 330 1969 180 gas 1965 D17 S-IV gas 1963 D17 S-III gas 1956 WD45 gas NF PS 1956 All-Crop 66 Big Bin 303 wire baler, 716H, 712H mowers |
Well I finally got over my Pneumonia and went out and found my serial number!
D17 14785 |
1958
Thank you Lonnie
Post Reply ![]() |
