Hey Coke HD5 question |
LouSWPA
Joined: 11 Sep 2009 Location: Clinton, Pa Points: 25548 |
Topic: Hey Coke HD5 questionPosted: 04 Dec 2009 at 2:11pm |
How much counterweight should I have on a G? Probably cost me as much as the tractor did, if I can even find them, but I think it would save a lot of stress on the truck frames
LouSWPA
Posted: 04 Dec 2009 at 3:36pm |
gemdozer
Posted: 04 Dec 2009 at 4:04pm |
I do't know how heavy is the HD5 counterweight but am still have one and
for the fuel he will prime him selve.
Coke-in-MN
Joined: 12 Sep 2009 Location: Afton MN Points: 42272 |
Posted: 05 Dec 2009 at 12:05pm |
My HD5G has 2 weights , which seems to balance well with full bucket. Without weights I have seen many machines with twisted truck frames from to much weight on front ideler, or bent axels in wheel.
Only time i have a problem is backing up ramp with full bucket , machine wants to walk on track raising machine rear, instead of moving backwards
Have seen weights with the AC logo cast into them and also like mine just flat with a lift rod in csnter cast into weight.
The 2-71 pump should prime the system but you could fill the filter cup with fuel. If you use the either sparingly to get it to run it will save on batteries. I use the 1/4" pipe plug hole in blower to add either. Edited by Coke-in-MN - 05 Dec 2009 at 12:08pm |
LouSWPA
Posted: 05 Dec 2009 at 2:05pm |
Yep, That's what happened to one of the two machines I have, the frame is (was, I fixed it) all twisted at the front idler, and I suspected thats what happened, someone did a lot of heavy lifting w/o counter weight. How heavy is a weight? I will probably build a frame work out of scrape and fill it with concrete, cheaper than buying real weights
Thanks for the help guys.
Coke-in-MN
Posted: 05 Dec 2009 at 3:17pm |
Unsure what the weight is in lbs. as far as scrap value most counter weights were low grade and most scrap places do not want them.
Friend junked several cranes and ended up paying a landfill to take the weights.
As someone has one , might be time for road trip .. LOL
wayneIA
Joined: 17 Oct 2009 Location: Waverly, IA Points: 268 |
Posted: 06 Dec 2009 at 8:04am |
On my Hd 5 I weighed the counter weight one time, if I remember correctly, it was somewhere between 750 to 1000 pounds.
LouSWPA
Posted: 06 Dec 2009 at 11:44am |
Thanks Wayne. I was guessing about 1000#'s would be about right
SHAMELESS
Joined: 13 Sep 2009 Location: EAST NE Points: 29486 |
Posted: 07 Dec 2009 at 4:28pm |
i'm trying to remember on my hg5, i think there was one weight above the drawbar on back, showed 1000# inscribed in the metal, it always seemed to stay level when the bucket was full of dirt. i don't have it anymore, otherwise i'd go look.
